Fog light fuse
Old Aug 16, 2017 | 02:21 PM
alexdc's Avatar
Default Fog light fuse
Hi everyone,
I think my fog light fuse blew but the problem is out of the two fuse panel under the hood. Only one has the sheet for the fuse placements.
Thank you!
Old Aug 16, 2017 | 02:39 PM
Default Re: Fog light fuse
Fuse #9 ( 15 amp ) in the fuse panel on the left end of the dash is the fog light fuse : ( fuse #13 is the spare )
Old Aug 16, 2017 | 08:52 PM
alexdc's Avatar
where the two plastic crew are when you open the door?
Old Aug 16, 2017 | 08:53 PM
Yes. Use a coin to turn them.
Old Aug 16, 2017 | 09:26 PM
alexdc's Avatar
Thank you so much!
Old Aug 17, 2017 | 12:04 PM
alexdc's Avatar
Turns out that it was a brake light but I think I've found some kind of a hack job behind that panel. Any idea why it's that way? Look (BTW I took the picture without the fuse but don't worry it's back in.)
Old Aug 17, 2017 | 01:11 PM
Steve Jr's Avatar
Don't know what they've done , but the wires are run into the the left and the right low beam fuse slots.
Old Aug 17, 2017 | 01:51 PM
alexdc's Avatar
When I turn switch to the P left and P right it turns on the left fog light then the right fog light on. Is that it?
Old Aug 17, 2017 | 02:00 PM
most likely, yes.
seems we may have a feed-back circuit here.
Old Aug 17, 2017 | 02:34 PM
alexdc's Avatar
most likely, yes.
Do you have any idea why they've done that?
Old Aug 17, 2017 | 03:25 PM
no, I don't
Old Aug 17, 2017 | 07:30 PM
Do you have the Canadian headlamp switch, a US switch or a US switch that has an adapter to change it to the daytime running lights set up required in Canada?
Old Aug 17, 2017 | 11:57 PM
alexdc's Avatar
How do I identify which switch I have?
I bought a car imported from the us but yes I live in Canada.
Old Aug 18, 2017 | 08:17 AM
That did not answer the question, so any one of my options is still on the table.
Which setup do you have?
Old Aug 22, 2017 | 11:49 AM
alexdc's Avatar
How do I identify which one I have?
