P0720 code
Old Oct 23, 2017 | 07:38 PM
Cobrasrt8's Avatar
Default P0720 code
I've had my 05 srt for almost 2 weeks and this is the second time this code (p0720) has come up. When it happens the trans will not up shift and of course the abs and bas lights come on. Any typical area to look at or do I need to start doing some electrical diagnosis?
Old Oct 23, 2017 | 09:04 PM
Steve Jr's Avatar
Default Re: P0720 code
Output speed sensor malfunction. My first guess would be, transmission circuit board not responding. But it also could be something as simple as wheel speed sensors or rings. Are you disconnecting the battery to reset the system , so your able to drive again?
Old Oct 23, 2017 | 10:43 PM
Cobrasrt8's Avatar
It did shift on it's own after a second or two, so no I didn't have to disconnect the battery. Why would a wheel speed sensor cause that? I can see it causing an abs light but not the shifting problem.
Old Oct 23, 2017 | 11:36 PM
Steve Jr's Avatar
The code is, Output Speed Sensor Malfuction. They work to report wheel speed , wheel slippage. It is only one of my hypothesis. Have you checked your fluid levels? Start with the basics. Like I said , my bet is the transmission conductor plate.
Old Oct 24, 2017 | 06:53 AM
What he said ^^^^^^^^^^
Old Oct 24, 2017 | 10:00 AM
There is a speed sensor on the transmission as I recall, I'll check it out.
Old May 15, 2019 | 05:57 PM
faSStcars's Avatar
What is the transmission conductor plate? Mine is doing the same thing. I picked the car up as a school project and it has been sitting for 4 years. Speedometer is not working so I thought they might be related.
Old May 15, 2019 | 10:24 PM
It is what is like the valve body in the 722.6 transmission, it connects 5 shift solenoids and a speed sensor and maybe some other components to the transmission control module.
There are tons of howto videos on uTube about changing it.
Old May 16, 2019 | 09:12 AM
faSStcars's Avatar
Ok I will look them up. Thanks for your reply I appreciate it. My students are excited to get to get started on it.
