Easy Question for the Veterans of the board, Air Filter
Old Apr 16, 2005 | 05:56 AM
oceancontainer's Avatar
Default Easy Question for the Veterans of the board, Air Filter
The silver cover on top of the engine that would normally house the air filter, how does that come off ? Does it have rubber gromets holding it in place and it just pops off or .....?
Last time I tried to remove something like this it didnt come off like I thought it would, instead it came off in pieces.
Drumroll gentlemen....
It says in my manual 60,000 miles or 4 years replace air filter ?
Did I read that correctly ?
Old Apr 16, 2005 | 08:41 AM
former NXMX5's Avatar
Default Re: Easy Question for the Veterans of the board, Air Filter
your '04 was manufactured in 11/04? sure its not an '05?
from what i read, the engine cover is held on by a bunch of rubber grommets, and some gentle tugging should do trick --
Old Apr 16, 2005 | 09:22 AM
andrew's Avatar
-C-I-C-C-I Associate Member
standing at the front of the car you first slip the round air intake hoses off the engine cover and push them aside.
the cover is held in place in rubber snap mounts...meaning you basically just pull up on it and it pops out of the mounts.
the easiest way is to grab it at the back first and pull up...then one side at the front and then the other.
Old Apr 16, 2005 | 09:34 AM
Dan Root's Avatar
Banned
Jump on the engine bay, one foot on each fender well, bend over and with both hands. PULL UP!!!!
BE careful not to fall on your tuchey!
Old Apr 16, 2005 | 03:46 PM
Thank you gentlemen. I knew I could count on you guys here. Last time I gave it a quick tug or jerked on something like this it came apart in pieces, t'was rather expensive to replace too. This cover is plastic too, figure I better ask first before I start jerking on this one. Terry
PNA
Nov 12, 2020 04:44 PM
sittininthesun
Aug 24, 2015 10:47 AM
cjfine
Jul 20, 2015 11:58 PM
waldig
Jul 20, 2015 08:10 AM
