64mm S/C pulley bearing
Old Nov 21, 2018 | 10:39 AM
DHS's Avatar
DHS
Default 64mm S/C pulley bearing
so I am changing to a 64 mm I got off the form, looks ok but would like to put in a new bearing,can’t find the part number on the form. Could somebody give me the part number for it?
Thanks
Dan
Old Nov 21, 2018 | 09:01 PM
RED DOG's Avatar
Default Re: 64mm S/C pulley bearing
I've never heard of a 64mm supercharger pulley??? If you get the old bearing pressed out and take it to your local NAPA, they can measure the bearing and match it up for a new one . . . Also I think most bearings have the size stamped right on the bearing.
Old Nov 22, 2018 | 08:10 PM
DHS's Avatar
DHS
I guess I was off by 1silly mm! It is the 65, and I can’t see a size. I guess a better question would have been, does the stock and 65 mm pulley use the same bearing?
dan
Old Nov 22, 2018 | 08:54 PM
Most bearings have a number stamped on them, not necessarily a size. The number can usually be crossed to other manufacturers.
James
Old Nov 22, 2018 | 11:30 PM
Thanks
Dan
Pulley bearings are listed in this PDF I did some years back. CLICK
You should be aware that this pulley might fail causing severe damage to area around the pulley, you should at least fit the pulley shield made by one of the members here, Latemodel21 is his handle.
If this pulley is aluminum I would not use it at all. If the rivets are loose do not use it. If the bearing is 55mm diameter you should not use it. The weakness is the wall thickness over the bearing, the material and the dog bone springs.
It should have a 47mm diameter bearing with a 5mm spacer.
All these after market pulleys will fail, the OEM pulley will fail one day, but not likely too soon, although their have been reported failures of them as well.
The earlier produced pulleys are disasters waiting to happen.
KnappAttack
Jul 26, 2016 08:28 PM
srt6Master
Jul 3, 2016 01:07 PM
ohnoesaz
Apr 18, 2011 03:12 PM
cruzinquick
Nov 7, 2009 08:54 PM
ohnoesaz
Jul 29, 2008 10:38 PM
