Blend Door Stuck, I Think??
Old Jul 8, 2021 | 01:41 PM
grotty7713's Avatar
Default Blend Door Stuck, I Think??
Posted something earlier and got good info, but I am wondering if there is any pictures or videos to get to the driver side blend door. Just wanted to make sure I know what I am looking at. I did take the dash apart on the driver side, just wanted to be confident in what I am doing. Please help me if you can.
Old Jul 8, 2021 | 03:44 PM
Default Re: Blend Door Stuck, I Think??
You said you had the dash apart, by chance did you have the A/C control head out? There are two 'keyed' shafts that must line up behind the A/C head when it goes back into the upper console/dash. Good luck!
Old Jul 8, 2021 | 04:21 PM
grotty7713's Avatar
I do have it out right now. Are those for changing location of where air comes out. I still haven't found the blend door on driver side. Ice cold air on passenger side, and got blowing out of the drivers side.
Old Jul 8, 2021 | 05:15 PM
Ifyou have hot air blowing out the drivers side the heater valve for the drivers side may be stuck open. There are two valves near the battery and LH the hoses are warm when the temperature wheels on the dash are set to cold (blue) you have found your problem.
Old Jul 8, 2021 | 06:22 PM
What onehundred80 said, most likely your duo valve. Who told you it was the blend door? I have never heard of one failing. Type duo valve into search at the top of this page. Also the Index of Crossfire problems link below onehundred80s signature has tons of info.
havpulse
Oct 24, 2016 09:40 AM
rdoherty
Apr 14, 2014 04:40 PM
popeye
Apr 10, 2010 03:20 PM
Sulley007
Mar 10, 2009 05:33 AM
popeye
Apr 18, 2008 12:29 PM
