P0154 code
Old Aug 2, 2021 | 03:46 PM
Ninocrossfire's Avatar
Default P0154 code
I have a 2005 limited coupe I change all oxygen sensors and P0154 code appear Does anybody could help me to diagnostic?
Old Aug 2, 2021 | 04:23 PM
Doc78's Avatar
Default Re: P0154 code
https://www.crossfireforum.org/forum...ouble-code.pdf
This is the PDF on this forum for the codes I looked it up and it looks like you were on the right track. P0154 O2 Sensor Circuit No Activity Detected (Bank 2 Sensor 1).
What code reader did you use? Did you clear the code after the repair?
Old Aug 2, 2021 | 07:17 PM
Hello Doc78 First I found O2 malfuntion and changed all sensors (bank 1+2 up and downstream)clear codes and work fine but after a month appear code P0154 and sometimes comes off and on Clean connection due to possible rust but same result Is there any other possibility I used an aftermarket sensor but I replace bank2 sensor1 w a brand new Bosh I appreciate Ur help Thanks
austinbarrylee
Dec 11, 2013 10:10 AM
purdy2005crossfire
May 16, 2011 05:30 PM
BLACKSRT-6
Nov 2, 2009 06:20 PM
Jake80
Jul 17, 2009 11:22 AM
Vmax01
Apr 27, 2009 11:05 PM
