PO410 code - blue check valve
Old Oct 1, 2021 | 05:09 PM
jecausey3's Avatar
Default PO410 code - blue check valve
Could this be replaced with another check valve of the same size ? Seems you can find many out there, just not an exact brand / part # match.
jecausey3's Avatar
Default Re: PO410 code - blue check valve
I realize this may be a dumb ?, Check eng lite just came on & threw out this code...
Old Oct 1, 2021 | 05:33 PM
Ronman's Avatar
Most of the time this is not the check valve but instead the RCM, relay control module.
Old Oct 2, 2021 | 12:04 PM
tighed1's Avatar
99% of the time code PO410 is burnt relay contacts on the air pump relay in the relay control module. Bet your's are burnt.
I can replace the relay for you.
Old Oct 2, 2021 | 12:31 PM
The P0410 code is a generic code that covers quite a few faults in the Secondary Air Injection system not just the blue valve.
P0410 Secondary Air Injection System Malfunction
Check the RCM for burnt contacts on the #5 relay shown here, CLICK
fric8489
Nov 15, 2021 12:37 PM
patpur
Oct 27, 2010 02:52 PM
theglot
Jun 9, 2009 08:14 AM
Vmax01
Apr 27, 2009 11:05 PM
Mimi05SRT6
Mar 11, 2009 03:31 PM
