How to unlock the gas door manually
Old Oct 17, 2021 | 11:45 PM
Fancyface831's Avatar
Default How to unlock the gas door manually
Cannot get my gas door open or unlocked how to
Old Oct 17, 2021 | 11:58 PM
Wadsworth's Avatar
Default Re: How to unlock the gas door manually
I am not aware of a lock. You just push in on the left side of the gas door at the ridge line and it should pop open. If it does not pop open maybe the spring release broke.
Old Oct 18, 2021 | 12:03 AM
Wadsworth's Avatar
Searched and found this thread.
https://www.crossfireforum.org/forum...mechanism.html
Old Oct 18, 2021 | 12:24 PM
It does have a lock pin to lock it closed when the car is locked to prevent the gas door from opening
Old Oct 18, 2021 | 12:37 PM
Sixkay's Avatar
the gas cover are opened and closed from the air tube coming out of the central locking pump. when i bought my crossfire the central locking system wasnt working and i was in the exact same spot as you. you have to open the trunk and remove some of the covers of the gas side and put in your arm between covering and the bodywork of the car. next to the gas is a level you can pull to manually open.
look at the picture. you need to find the red part by feel:
https://www.crossfireforum.org/forum...chanism-72.jpg
cobraken
Feb 24, 2014 11:50 PM
downwardspiral
Aug 7, 2008 04:10 AM
harbor
Mar 2, 2007 11:36 PM
