Gearbox
Old Oct 29, 2021 | 02:06 AM
Simrie's Avatar
Default Gearbox
My xfire won't change up gear, im told it is corrosion on the pcb and is a specialist job. Can anyone suggest where in Scotland I can get this done.
thank you.
Old Oct 29, 2021 | 03:29 AM
Viper-666's Avatar
Default Re: Gearbox
What PCB do you mean the one from the TCM under the floor on the passenger side? If yes there are only two possibilities why it have corrosion:
1. The drains for the rainwater under the hood are clocked and water comes into the crossfire.
2. The seal at the plug of the transmission is leaking and the oil goes over the harness in the TCM and destroyed it.
So you have first to solve the issue what gets the TCM to be corroded.
You can buy a used TCM (look at the Part number and software version to buy the same). I don't think a repair is the best option.
Old Oct 29, 2021 | 01:11 PM
Simrie's Avatar
Default Re: Gearbox
I believe its the TCM that is the problem and has to be replaced, unfortunately I can't find someone to do it but keep being told it will be in excess of £600.
thanks for the reply !
Old Oct 29, 2021 | 05:46 PM
Default Re: Gearbox
look on ebay lots of them look at yours and get the same p/n they are from $75 up. you should also get a rcm (Mercedes K40) those interchange srt6 and limited,
Old Oct 30, 2021 | 01:16 PM
Viper-666's Avatar
Default Re: Gearbox
You can find some TCMs here: ebay TCM A0335451232 please confirm that you have the same part number.
And here you can find the module, you need only a 10mm wrench to open the three black plastic nuts:
But how I wrote, you have to find the reason why it corrodes.
Old Oct 31, 2021 | 12:59 AM
Simrie's Avatar
Default Re: Gearbox
Once again thank you some much for the help I am so grateful.
I am on nightshift and upside down at the moment.
I gave the fail code somewhere and if it is the TCM ( im sure it is ) I'll definitely replace it myself.
Joel
Nov 29, 2014 10:49 PM
h4auto
May 21, 2008 01:47 AM
Xfirenorth
Mar 26, 2008 10:54 AM
ljcasey
Apr 27, 2007 12:12 PM
Indoalbano
Apr 15, 2006 01:25 PM
