chrysler crossfire thermostat housing O ring
Old Jan 23, 2022 | 03:32 PM
Default chrysler crossfire thermostat housing O ring
Anyone have a source for a chrysler crossfire thermostat housing O ring?
Old Jan 23, 2022 | 03:51 PM
zip439's Avatar
Default Re: chrysler crossfire thermostat housing O ring
If you know the size these guys will have it: www.theoringstore.com
Old Jan 23, 2022 | 04:23 PM
Find an industrial supply store and take it or the housing and get a Viton O ring the same size. Remember it has to fit on the outside diameter loosely, do not stretch it to fit the inside diameter.
Old Jan 23, 2022 | 04:52 PM
Ronman's Avatar
The Mercedes part number is 1122030076 if that helps. Might as well change the thermostat too while you are at it, it comes with the O-ring and is not terribly expensive.
Old Jan 23, 2022 | 05:57 PM
Thanks
Old Jan 24, 2022 | 09:04 AM
nemiro's Avatar
It's not a round type O ring, but a squared off one, and then it has some other shapes to it. In other words, you really can't replace it with a generic O-ring. If the o-ring is leaking, it's probably time for the thermostat, too. As suggested, get one with a thermostat.
Old Jan 24, 2022 | 09:31 AM
Yeah, I could have called it a gasket but then it is not really a gasket either, I am just removing the housing and thermostat for a coolant flush and saw no need to replace the housing or thermostat. The old one may be fine to reuse but I figured better to replace. THANKS
loudrango
Crossfire Events and Meets
Jul 18, 2021 09:50 AM
SpeedBallDEVIL
Aug 31, 2014 02:52 PM
FADDING
Apr 7, 2012 05:02 PM
MI1XFIRE
Nov 8, 2007 07:12 AM
Emthusiast
Nov 29, 2006 11:28 PM
