Cowl Removal Problem
Old Jul 15, 2023 | 01:07 PM
avgfan's Avatar
Default Cowl Removal Problem
OK. My Passenger cowl drain is clogged. I've removed the wipers and removed the screws holding the cowl grill in place. However, I can't lift the cowl grill up high enough to see the washer tube and other connections. How do I unhook all that stuff?
Old Jul 15, 2023 | 02:01 PM
Default Re: Cowl Removal Problem
Did you cut the two plastic zip ties?
Old Jul 15, 2023 | 06:43 PM
avgfan's Avatar
I didn't see any plastic zip ties but I got the thing off. I cleaned the drains but now, I can't get the center cowl drain back on. The rubber hose is too stiff or long to allow me to push the bottom of the drain in place. The top of the drain also gets pinched out of shape by the wiper motor. What am I doing wrong?
Old Jul 16, 2023 | 12:35 PM
dcskmail's Avatar
Here are several videos that may help, you might want to disconnect the alarm while you're in there most of them fail dragging down the car battery
go to youtube and type in crossfire cowl removal, It won't let me post the link on the forums
Old Jul 16, 2023 | 01:09 PM
Old Jul 16, 2023 | 01:35 PM
avgfan's Avatar
I used this video to do the job. It's a great video! I've already removed the alarm. However, he doesn't show how to put the center drain pipe back in. The hose is bent in an S (kind of). When I get the hose in, no matter which way I turn the funnel, I can't get the botton to seat in the hole. Instructions say to turn it clockwise to insert it but to do that pinches the funnel and in fact, mine cracked. I've just ordered a new one Mercedes-Benz Drain Pipe - (170-830-01-25). I still can't get the *#*#*#* in!
Old Jul 16, 2023 | 03:07 PM
I never removed the tubes. I just vacuumed the debris and ran a 1/4 " flexible tube through to be sure it was clear.
Old Jul 16, 2023 | 07:38 PM
Have you tried some dish soap mixed with water to make it slippery?
Old Jul 17, 2023 | 09:43 AM
While under the cowl it is a good time to clean the WW nozzles and remove the hoses from the nozzle and put pump some WW fluid through the lines. The top of the jets bodies snap up and expose the ball shape nozzle,
Old Jul 19, 2023 | 07:42 PM
avgfan's Avatar
Thanks for the tip! I'll do that.
popeye
Jul 24, 2015 06:19 AM
gualtira
Nov 5, 2014 06:54 PM
Cyril Baldwin
Apr 6, 2013 10:29 AM
dtinker
Dec 30, 2010 09:21 PM
unclebart
May 15, 2009 10:42 PM
