2005 Cat Converter in/out size?
Old Nov 29, 2025 | 09:30 PM
Romad's Avatar
Default 2005 Cat Converter in/out size?
Before I remove the driver's side cat converter I want to order replacement cat. Anyone know for sure the in/out diameter? Listed as 2" / 2.5" / 3". Car has been sitting on the side of the house for about a year with a split cat converter at the weld. Good thing I have two other Xfires to get around with! LoL
Old Nov 30, 2025 | 08:28 AM
Default Re: 2005 Cat Converter in/out size?
Why not just reweld it?
Old Dec 1, 2025 | 01:24 PM
zip439's Avatar
I had a split seam on the driver's side forward cat years ago. Removed it from the car, welded it myself and reinstalled. Cost = zero and it is still on my car functioning just fine.
Old Dec 1, 2025 | 03:13 PM
Romad's Avatar
Need a welder and how to use it! Muffler shops won't do it cause they said it's against the law to replace just the cat. Part of the stolen cat problem even though it's brand new cat!
Old Dec 1, 2025 | 03:43 PM
Instead of replacing it, just have them repair the weld.
Old Dec 1, 2025 | 03:53 PM
Romad's Avatar
I don't want to deal with rewelding. I just want to use pipe clamps and keep it simple if possible. New EPA approved free flow cat, "so they say," is $45 on eBay.
"Truth be told," I found, months ago, a used cat and ran into the above mentioned problems. I cut and used clamps to install it but not a very good job. One pipe was not round and not a good fit and makes some noise. Now I have time, "more or less," ito install a new cat better with no leak. If I could find someone to weld it I would and forget the new cat! When your laying on your back in the driveway things are never simple.
Old Dec 1, 2025 | 05:11 PM
In California they must be welded on.
Old Dec 3, 2025 | 09:11 AM
tmpa xfire's Avatar
Once you know the required diameter and length, look into Jeg's or Summit for a free flow cat. They also have wrap around clamps that will not leak..I would stay away from Ebay.
Old Dec 3, 2025 | 05:06 PM
bc75's Avatar
Look on ebay i just bought the complete exhaust. section before the muffler all 4 cats. from a slk they are the same shipping and all $720 no welding just bolt on.
Old Dec 3, 2025 | 06:40 PM
Romad's Avatar
I appreciate the tip "but" spending $720 instead of $50 weld job just doesn't make good sense to me. When you have three Crossfires you have to be a little frugal with the money you spend to keep the fleet gooing. LoL
brnhn3
Feb 5, 2017 04:03 PM
Selbyl
Jul 30, 2013 10:57 AM
syfi
Dec 31, 2012 11:15 PM
floyd
May 10, 2011 06:03 PM
woody
Nov 18, 2006 07:26 PM
