Car hesitates as clutch is depressed
Old Mar 3, 2006 | 09:05 PM
BlackCrossFire6spd's Avatar
Default Car hesitates as clutch is depressed
I just bought a black '05 on Saturday, and I LOVE the car. I am having a problem with the transmission/clutch however. I am going to bring it into the dealership since I finally noticed the FSS is showing -174 on the display, and insist they give me a free oil change, but onto my problem. As I am driving, when I depress the clutch, the car jerks like it is not getting fuel for a split second, and the car shudders from the quick deceleration. But a split second later, everything is normal. And if I "bounce" my foot on the clutch pedal, not far enough to start disengaging the clutch, it will jump everytime I press it down. Has anybody had a problem like this or have any idea what I may be so I can be a little more educated on this before I go to the dealer? I am a newbie, and I have spent a lot of time looking for something regarding this, and have found nothing, so any help would be appreciated. Thanks.
Old Mar 4, 2006 | 04:47 PM
jpristel's Avatar
Default Re: Car hesitates as clutch is depressed
The only hesitation that I've noticed is that as I depress the clutch the car bogs down as if it is a lot heavier than it really is. My old camaro (which weighed over 500 lbs heavier) didn't feel quite as heavy when it comes to getting this car rolling.
Old Mar 4, 2006 | 07:11 PM
knowit's Avatar
There is a switch that is connected to the clutch pedal. As you depress the clutch it does something to the power train control module that reduces the power from the engine. The way to avoid it is to fully lift off the gas before depressing the clutch. Good timing goes a long way while driving this car. Totally normal.
Old Jul 10, 2006 | 02:21 PM
chuckd's Avatar
My wife's car does this. I noticed it today. It did it several times.
I will be taking it in to be checked out. I've owned many cars with manual transmissions and never had one cut out like that or hesitate going into the next gear. It's annoying, but I'll try what you suggest and see if that helps.
Old Jul 17, 2006 | 01:57 PM
That is the same problem that I have been having. My Silvia was butter smooth. I've got the timing of the xf down, but sometimes i get lazy while driving and I'm off a little, and the engine cuts the power, and it will throw me out of gear while i'm in the middle of shifting. if anyone knows if you can de-program this from the computer, that would be great.
Old Jul 17, 2006 | 04:50 PM
chuckd's Avatar
I'm with you. I've found that most of the time it's from my clutch foot resting on the clutch. If I concentrate on taking it off, it doesn't seem to do it. It's never thrown me out of gear, but it's annoying. Every car I've ever had was a manual and I've never dealt with something this precise. I've driven Mustangs, Corvettes, Camaros, Mazdas, many trucks and other things. I guess this car is just that picky! Still a blast to drive!
Old Jul 17, 2006 | 05:42 PM
feets's Avatar
It's designed to prevent shattering drivelines by abusing the clutch. It's normal. Working on your timing is the key to stopping this.
Old Jul 18, 2006 | 11:39 PM
markr6754's Avatar
I thought it was just me. Most days I've got the timing, but I've got to say it's taking more than other cars to get the hang of it. My biggest problem is 1st to 2nd. Start with the fact that this is the notchiest transition...and if I hesitate at all I've missed the shift and have to double clutch it. However, when my timing is on...oh how sweet. And that's what I live for.
Old Jul 19, 2006 | 02:06 AM
chuckd's Avatar
Ours is typically 4th to 5th or rd to 4th. Every other gear is fine.
It seems to have calmed down since I remember to take my foot off the clutch now, instead of resting on it.
Old Aug 5, 2006 | 12:50 PM
I have an update on this issue. I recently brought my car to te dealership for some warranty work which required the tech to test drive the car. Apparently he noticed the same thing that I did, and it is fixed now! The car does still back off power when the clutch is depressed, but it is MUCH smoother than it used to be. I also had bogging when I would drop to second coming out of a turn, and now it doesn't. My car now drives the way it is supposed to drive, which is amazing! If anyone is having similar problems, take a tech for a test drive with you and point it out to him, and they should be able to fix it. I can't get an answer from my dealership for what they did to correct this, but if my service writer finds out, he'll let me know, and I will post it here.
Old Aug 21, 2006 | 10:48 AM
afws04's Avatar
Banned
mine did it too, it's not normal, if you've put alot of miles on your crossfire and know it very well you'll detect it - it's a cam shaft sensor, controls timing etc, it only gets worse if you ignore it... its visible right on the front of the engine, lots of them coming loose, dirty, etc... mine was fried, caused the whole car to shake and misfire eventually.
vspuds
Oct 11, 2018 05:16 PM
mhajek18
Dec 30, 2015 03:40 PM
vinnys
Jun 29, 2015 09:33 PM
krooner
Other Cars Etc
Jan 24, 2004 10:00 AM
