All this talk about cd.....
Old Mar 14, 2006 | 08:33 AM
CrossfireSweden's Avatar
Default All this talk about cd.....
I am about to change the original cd to a JVC, in all the threads i've read everybody talks about amps and subs.
If i only is gone change the cd, do i have to change amp and etc. or is it just change?
Does anybody have pictures of a change?
Best Regards,
Peter
Old Mar 15, 2006 | 10:47 AM
former NXMX5's Avatar
Default Re: All this talk about cd.....
you don't need to change amps and speakers to change the head unit. You can buy any head unit you want, and as long as you get the right wiring adapter (Scosche VW01) and antenna adapter (Metra 40-EU10) you'll be fine. I also installed a JVC, and just make sure you use the PRE-OUTS instead of the amplified SPEAKER outputs for your speaker connections --
good luck!
Old Mar 15, 2006 | 10:50 AM
Just noticed you're from Sweden. The correct antenna adapter for you might be different than the US. A car stereo shop should be able to point you in the right direction; and it shouldn't cost you more than $10-15 (USD).
o55ie18
Oct 5, 2015 05:50 PM
Mackel
Sep 29, 2015 02:41 PM
JEFASOLD
Sep 28, 2015 12:10 PM
brandoni
Sep 6, 2015 07:35 PM
