Question about stock amplifier (limited)
Old May 14, 2010 | 06:52 AM
Infinite's Avatar
Default Question about stock amplifier (limited)
SO today im working on getting the wiring in place for the sub im installing in my 07 limited.
My question is this, are the outputs from the radio filtered, as in, do the front speakers receive full spectrum sound are the rear speakers (subs) just low pass?
Im going to tap the factory wiring pre-amplifier and piggy back those rear speaker inputs to the amp for the sub, im just wondering if I should pick up a low-pass filter or not if the signal is already filtered by the stock headunit.
Old May 14, 2010 | 07:48 AM
maxcichon's Avatar
Default Re: Question about stock amplifier (limited)
So far as I know, all 4 places receive the same signal.
Old May 15, 2010 | 04:48 PM
Airscape's Avatar
The rears are filtered in the amp so if you break it out from the HU you should be getting full.
Old May 15, 2010 | 06:22 PM
Infinite's Avatar
thanks, for now i want to leave to stock amp in place until i (might) do a full system.
Old Aug 1, 2011 | 05:06 PM
mikeandyance's Avatar
how can i wire the rca jacks straight into the amp??? back subs dont work ..connector broke...what color are the rear subs on the amp clip?
Old Aug 1, 2011 | 07:49 PM
redeagle's Avatar
Here is link that might help:
https://www.crossfireforum.org/forum...-channels.html
Also here is a link to the amp wiring schematic:
https://www.crossfireforum.org/forum...io_diagram.pdf
Here is a visual guide to XF wire harness and amplifer connectors:
http://crutchfield.custhelp.com/app/...0/kw/crossfire
Jul 29, 2015 06:13 PM
mobilefitt
Jul 28, 2015 03:45 PM
pioneer4x4
Jul 27, 2015 02:04 PM
axnguyen
Jul 21, 2015 11:41 AM
Dave Wilson
Jul 18, 2015 05:31 PM
