why won't my subs work in my car
how can i hard wire the rca imputs to the amp its self and will this solve my problem have a alpine 9886 everything is connected right but no wires for the subs besides the rcas that come from the main harness
Re: why wont my subbs work in my car
You are talking about a sub box for in the hatch right and not the stock "subs" behind the seats right?
how do you hardline the subs to the amp what wires do i splice so i can turn it into an rca wire
Wiring A Car Amplifier i hope this helps
pay a mind to the amp turn on wire!!! This caused me headaches |
@mikeandyance - I read your question to mean you wish to use the sub outputs from your new Alpine HU to connect to the stock "subs" (rear speakers) If this is what you want to do you will need to splice on RCA connectors to the wire harness. I would splice on 4 RCA connectors -
Splice RCA jacks to the harness wires that go to the front and rear speakers (rear speakers are the "subs" in the Crossfire) - then plug them into the HU's Pre-Amp Front Speaker RCAs and the SubWoofer RCAs Your HU has enough pre-amp voltage (4 volts) for the factory amp to do a decent job. This should give you a cleaner sound by bypassing the HU's built in amp. Here is a diagram of the Crossfire Wire Harness: 2004-2007 Chrysler Crossfire with Infinity Wiring Information Hope that helps |
Splice RCA jacks to the harnes wires that go to the front and rear speakers (rear speakers are the "subs" in the Crossfire) - then plug them into the HU's Pre-Amp Front Speaker RCAs and the SubWoofer RCAs Your HU has enough pre-amp voltage (4 volts) for the factory amp to do a decent job. This should give you a cleaner sound by bypassing the HU's built in amp. Here is a diagram of the Crossfire Wire Harness: 2004-2007 Chrysler Crossfire with Infinity Wiring Information Hope that helps |
k..thanks now i got a 12in sub 400wtt..i want the hu to power the doors and the amp for the sub...install ideas?
| All times are GMT -4. The time now is 03:07 PM. |
© 2026 MH Sub I, LLC dba Internet Brands
