4 channell amp help
Old Jan 21, 2016 | 05:18 PM
rodrofilo's Avatar
Default 4 channell amp help
Hi im new to the forum im taking the oportunity to introduce myself and ask a question, what is the advantage of using the amp as a 4 chan? Besides the fader, i mean does it sound louder, or is the quality better??? Im sorry im pretty hopless when it comes to audio electronics
Old Jan 24, 2016 | 10:29 PM
Default Re: 4 channell amp help
The idea is that you could customize both the sound level AND equalization to each speaker. Of course, that doesn't work well with the original head units the cars came with. But with the newer head units you can buy these days, you can set it up so that you only send bass to the rear speakers - which would be, in my mind, a great advantage.
Also, you could cut all bass to the door speakers, which helps as those speakers don't handle bass very well - that is why we do the "biggest bang for the buck" audio modification, we add capacitors in the doors to cut bass to the small tweeter speakers, which REALLY improves their performance.
Also, with six speakers in the car, if you don't drive them using more than two channel amps, the impedance you are driving with the amp is just too low. That is, three speakers in parallel would work out to less than 2 ohms per channel - just too low.
Old Jan 24, 2016 | 11:20 PM
rodrofilo's Avatar
Thanks for the info pizzaguy, i am going to do the mod for the amp, ill let you know how it went!
Dementors
Feb 4, 2016 05:31 PM
Flatline05CFire
Jan 20, 2016 10:14 PM
flax43
Jan 20, 2016 01:51 PM
Crossfiren
Jan 11, 2016 12:21 PM
Padgett
Dec 31, 2015 09:59 AM
