Rear wing locked in the up position
Old Aug 20, 2006 | 11:26 AM
DontShoot's Avatar
Unhappy Rear wing locked in the up position
Wing locked, will not move up or down. Suggestions?
Old Aug 20, 2006 | 12:24 PM
danimal's Avatar
Default Re: Rear wing locked in the up position
Check fuses. Also try running it above deploy speed and then slow down to below retract speed and see if it resets itself (mine hung once and that worked for me). Good luck.
Old Aug 20, 2006 | 03:37 PM
cgates's Avatar
Did you try opening and closing the rear hatch then pushing the down switch?
When my Crossfire was new, my wing would go up, but not down until I did the
above. Turned out the wing unit needed to be replaced.
Old Aug 20, 2006 | 03:46 PM
acrispy1's Avatar
I had the same problem the very day I drove it home from the showroom, took 5 service calls to get it fixed.
Old Aug 20, 2006 | 05:58 PM
VQ35DE's Avatar
Maybe it's just happy to see you.
Old Aug 21, 2006 | 04:27 PM
DontShoot's Avatar
Thumbs up Re: Rear wing locked in the up position
Thanks guys or ladies, will try your suggestions...bty...VQ...good line.
Old Aug 21, 2006 | 04:58 PM
Sennaspirit's Avatar
T,
What was the problem in the end? Motor? Electrical?
Old Aug 23, 2006 | 05:10 PM
DontShoot's Avatar
Thanks for the info guys, but...no luck...looks like a trip to the service dept. I will post the outcome in a few days...thanks again.
Old Aug 23, 2006 | 08:49 PM
acrispy1's Avatar
Originally Posted by Sennaspirit
T,
It was the motor.
jhansen
21
Feb 15, 2017 04:26 PM
sittininthesun
Aug 24, 2015 10:47 AM
Cuda56
Aug 11, 2015 12:11 PM
BrenLW
Aug 5, 2015 04:53 AM
Trenzman
Jul 24, 2015 10:12 PM
