Xfire's Best Features
Hi Everyone. I think it would be cool to start a thread that lists some cool features that most people don't know our xfire's have. For future owners! Here is some I know. Everyone add the ones I missed!
Driver Convenience: Cabin Air Filtration System - Fresh Clean Filtered Air inside Cabin :) - Also cuts down on cabin dust. Driver Convenience: Recirculation Button - Prevents outside air (dust and odors) from entering your vehicles cabin. You can also use this feature to keep warming your cabin for 30 mins when it is cold outside. Convenience: Locking Gas Door Driver Convenience: Speed Sensitive Wipers - Wipers will change from normal mode to intermittent mode while stopped to prevent the wipers from going across a dry windshield. Serviceability: Oil Level Sensor - Alerts you when the oil level is too high or low. Serviceability: Anti Tow Away Alarm - When engaged if someone tries to tow the car the alarm will go off and the lights will start to flash. Driver Convenience: Integrated Key Remote - The key and remote are one piece. The keys flips out of the remote like a switchblade. Serviceability: Tire Pressure Monitoring System - A light will illuminate on the dash if the tire pressure is too low. Most people dont check this enough. It shouldn't replace your own checking but it helps. Serviceability: Flexible Service System - Helps you keep track of when service is due and what service is due. |
Re: Xfire's Best Features
Automatic Transmission Program mode selector switch: The transmission is provided with a selector switch for Standard “S” and Winter/Wet “W” (snow and ice) program modes.
Driver Convenience: Telescoping Steering Wheel. Serviceability: Top accessible oil filter element that is easily removed without mess. Serviceability: Light Outage Indicator With the key in the ignition switch turned to the ON/RUN position, an indicator light comes on. It should go out when the engine is running. If the indicator light does not go out after starting the engine, or if it comes on while driving, it indicates a failure in the parking light, taillight, stoplight, or low beam headlight. The indicator light will come on when the exterior light fails. If a brake light fails, the light outage indicator will come on when applying the brake and stays on until the engine is turned off. Safety - Electronic Stability Program (ESP): The ESP enhances directional control and reduces driving wheel spin of the vehicle under various driving conditions. The ESP system corrects for over/understeering of the vehicle by applying brakes to the appropriate wheel. Engine torque is also limited. The ESP warning light, located in the instrument cluster, starts to flash as soon as the tires lose traction and the wheels begin to spin. Convenience: Dual climate temperature controls. Convenience: Heated seats. Convenience: Dual 'one touch down' power windows. Convenience: The HomeLink Universal Transceiver replaces up to three remote controls (hand-held transmitters) that operate devices such as garage door openers, motorized gates, or home lighting. The transceiver triggers these devices at the push of a button. The transceiver operates off your vehicle’s battery and charging system: no batteries are needed. Convenience: Umbrella Hook. Your Crossfire is equipped with an umbrella hook. This feature is located behind and between the two seats, just above the map pocket. Night Security Illumination: For added security when exiting the vehicle after driving with the exterior lights on, the lights will switch on again for approximately 30 seconds after closing the last door. The lights-on timing can be changed at your authorized dealer. For those who wish to know more... you can download the owners manuals from this thread. |
It corners real good.
Polite headlights (the top of the beam is cut off). It corners real good. Automatic darkening rear view mirror. It corners real good. Door pockets (a great feature I've missed since I owned old Triumphs). It corners real good. |
The best feature of the Crossfire is the window sticker. :cool:
Hum, never knew it was an umbrella hook. I thought it was some kind of coat hook, where you hooked a hanger on it, and put the coat in the hatch. Never actually did it. Wonder how effective the hooks are for an umbrella, seems a little backward since the hook latches push in, and it seems like it would hit the umbrella and make it hard to get out. And what good does the anti-tow away do? If the guy is going to tow your car, he's doing to do it with the horn and lights going off. He's not gonna stop and leave because of the horn.
Oh and I think the dual climate control and dual heated seats are one of the best convenience features. I also like how there's no button on the auto-sticks, you can just rock the shifter from park to drive. |
If the alarm is going off doesn't the engine become immobilized therefore the car cannot be shifted in neutral? If the car cannot be shifted out of park it cannot be towed correct?
If the alarm is going off doesn't the engine become immobilized therefore the car cannot be shifted in neutral? If the car cannot be shifted out of park it cannot be towed correct ?
Corn-venience:
Radio can be operated w/ key removed. |
The umbrella hook is for the 'strap' on an umbrella, so that it will hang down behind the seat.
Ohh, i see, usually just throw mine in the hatch.
WHAT Locking gas cap?
And I tested that tow alarm...ahahaha. Woke my wife up from Napcar... :) |
WHAT Locking gas cap? |
yeah you can see it, open the gas door then lock your car. a little silver bar on the left side will slide out and lock unto the door if it was closed.
Originally Posted by RPM
Not only does the gas door lock with the doors, but on the roadsters (don't think it's on coupes, not certain though), the center console locks too.
It also corners real good. |
Hello CF Enthusiasts,
Another feature for the Roadster Only...besides the individual window switch for each window...you can use the Roadster Top Down switch to raise and lower both windows together at the same time! Also...on the Roadster only..when you turn the Roof Latch to unhook and lower the rag-top roof...both windows lower automatically! Cool! Also...was it mentioned that you have a manual override switch for the Auto Rear Spoiler (not on SRT) , so you can put it up and leave it up! |
Originally Posted by 04Fire
WOW didn't know that... I'm pretty sure my coupe doesn't do that, but that's still way cool.
It also corners real good. This feature is a programmable key-fob option that you can program yourself!!!...but I forget how to do it...but Stryfox and others know how to do it. |
| All times are GMT -4. The time now is 11:24 AM. |
© 2026 MH Sub I, LLC dba Internet Brands
