CrossfireForum - The Chrysler Crossfire and SRT6 Resource (https://www.crossfireforum.org/forum/)
-   Crossfire Coupe (https://www.crossfireforum.org/forum/crossfire-coupe/)
-   -   TSB's How do They work? (https://www.crossfireforum.org/forum/crossfire-coupe/16169-tsbs-how-do-they-work.html)
rakoom2002 Jun 12, 2007 09:22 PM
I keep seeing this useful information about TSB's that apply to my car, but how do they work? I have asked a few times and no one has responded. does the dealer pay to get them fixed? does the car have to still be under warranty? How do you get the dealer to recognize and fix the problem besides calling them and saying" hey there's a tsb out for this, fix it please" and having them saying "screw off!"?
old man Jun 12, 2007 10:05 PM
Re: TSB's How do They work?
tsb are not under warranty.
rakoom2002 Jun 12, 2007 10:20 PM
okay, thanks but you only answered like part of one of my questions...
ben47 Jun 12, 2007 11:52 PM
TSB's are Technical Service Bulletins.
They are published to aid the technician and to disseminate information on a certain
issue, usually an uncommon problem or procedure. They can range from cleaning
chrome wheels to correcting a transmission problem. TSB's therefore have nothing
to do with the warranty on your car, unless it covers a problem that is under warranty...
polywave Jun 13, 2007 09:51 AM
They can tell us to screw off.
C_Plunkett Jun 13, 2007 11:32 AM
I'm not sure how Chrysler works, but Ford refused to perform a TSB on my previous vehicle because it was out of the factory warranty. Once it became a recall they had to fix it.
rakoom2002 Jun 13, 2007 11:33 AM
thanks guys. is there a list of recalls?
Sidez Jun 13, 2007 03:27 PM
yea there is check the TSB and HOW to Forum... it is stickied there...
NoCones Jun 13, 2007 04:11 PM
You mean they refused to perform it for *free*.
I'm sure Chrysler would be the same way...a TSB is merely a guide for a technician...basically, "here's a symptom/problem a lot of people have...and here's a technique for fixing it." If a car is out of warranty, a recall is the only thing that's going to get done for free.
rakoom2002 Jun 13, 2007 04:34 PM
Okay lemme ask you this. my car is still under warranty and I am having a problem with dried condensation in my headlight causing hazing in the headlight. I took the car in when the condensation was still wet and the guy said this was normal, he did nothing about it, now as a result I have the hazing. If I bring in the tsb and show them the head lights now, are they required to fix and or replace under warranty?
CrossfireLTD Jun 14, 2007 02:03 AM
This is not normal and should be covered under warranty. There are 2 fixes for the problem and totally up to the dealer. The first is to install a "vent kit" to the headlamps, if this does not work (and it usually doesn't) the headlamps should be replaced under warranty. I have had my headlamps replaced 3 times under warranty, 2 vent kits and then they were finally replaced under warranty.
TBS: 13-Jan-05 - 08-002-05 - Lighting - Condensation in Headlamps
rakoom2002 Jun 14, 2007 03:14 AM
okay then so if I bring in the tsb they shouldn't have a problem doing either of the repairs?
chxf Jun 14, 2007 08:15 AM
See my post in the technical/TSB -> https://www.crossfireforum.org/forum...131#post135131
© 2026 MH Sub I, LLC dba Internet Brands
