Installing CTD chrome lower grills
Old Aug 1, 2007 | 02:16 AM
Cyril Baldwin's Avatar
Default Installing CTD chrome lower grills
I received mine today without a manual on how to install. Do I need to remove the front grill to install it and bend the tab to lock it?
Any tips with the install?
Old Aug 14, 2007 | 11:24 AM
rock's Avatar
Default Re: Installing CTD chrome lower grills
I have no installation tips, but can I ask how much you paid for them?
Old Aug 21, 2007 | 12:40 AM
I paid $184 for the lower grills thinking it's an easy install compared to the other one that I was looking at on Ebay.
I hope Tino from CTD-Germany can reply on this or post a manual in this forum. I still hasn't installed it yet.
Old Aug 21, 2007 | 05:28 AM
Sidez's Avatar
I also have no advice for you, but can you post pics when it is installed please...
The only thing I can tell you is something you probably know and that the lower grill has to be removed via the car's all purpose tool. I am guessing that the this new grill takes it's place and is hopefully a fit perfect for it's position...
Old Aug 22, 2007 | 05:51 AM
Smoked's Avatar
That seems a bit steep - I bought mine from ebay for £20 ($40) and looks pretty good... It is held on with silver colored zip ties.
Old Aug 22, 2007 | 06:59 AM
Sidez's Avatar
his are full replacements, much higher quality than ours...
Old Aug 22, 2007 | 07:05 AM
Smoked's Avatar
Might have known that I bought the cheap *** solution...
Old Aug 22, 2007 | 08:55 PM
CTD-Germany.com's Avatar
cyril,
you can anytime send us a email if you have problems or questions. i'm not every day at this forum to check all the posts.
sidez has see it right, the lower grilles are full replacement parts, so you must first remove the original plastic parts. if they are removed, you can fit the lower grille in the original mounting points. bend the stripes to fix the grille. that's all.
tino
Old Aug 23, 2007 | 08:21 AM
Steve Hellums's Avatar
I have the slotted stainless lower grill's. My best advice is to remove your old plastic one's, then go ahead and install the little brackets on the outsides of the new grill's that hold them in. Then start with placing the outside end in first so that the little bracket catches the place were the old one's latched. Then bow the center of the new grill outward enough to insert the two tabs into the holes for them in the center of the car and then carefully push the center in while holding down the lower part of the opening that they fit in so that you won't scratch the paint. The new one's will set in about a half an inch, so be sure to clean the openings real good before the install. I hope this helps.
Old Aug 25, 2007 | 03:25 PM
I finally figure out a better way to install it. It ain't easy cause it took me 45 minutes analyzing how to secure it right...i hope so. The middle tabs from the CTD grill is too long that it didn't really serve a purpose but an eye sore cause you have to just fold it out of the way. The outside tabs which are also long...I shaped it like a hook then fold it inwards so that it'll be out of the way when I install the grill. Then I push it in with a screw drive so that it will act like an anchor hook for the grill.
Overall review, I just hope it'll stay in place because it's only the center tabs that are holding it in place. CTD should make thicker tabs to make it a tight fit.
The grills look great and an outstanding quality product for our crossfires. Thanks CTD for this product and I hope this forum can give you guys more ideas in improving your products.
Old Aug 25, 2007 | 07:33 PM
It looks great. I like it.
Old Aug 26, 2007 | 10:57 PM
04Fire's Avatar
That looks real good!
Can you get a pic from further away and up higher?
Thanks.
Old Aug 26, 2007 | 11:07 PM
Here's how it looks like in the side angle and just a little view from above.
xfireohio
Jul 20, 2020 12:03 AM
waldig
Sep 2, 2015 11:02 AM
maxcichon
Jul 31, 2015 06:35 PM
KDW4Him
Jul 31, 2015 10:21 AM
Jul 29, 2015 06:13 PM
