Seat adjustment
Old Oct 9, 2007 | 02:28 PM
Grover Orndoff's Avatar
Default Seat adjustment
Have recently purchased a 2005 Crossfire with manual seat adjustments. The lever on the driver's side doesn't seem to work. Checked under the seat and it is connected. With nothing in the manual and the dealer knew less than I did, is the purpose of this adjustment is to make the seat raise and lower or what?
Old Oct 9, 2007 | 02:56 PM
CrossfireLTD's Avatar
Cool Re: Seat adjustment
Congrats & Welcome to the Forum!!!
If I am not mistaken the seat adjustment on the "Base" models is only forward and back.
Old Oct 9, 2007 | 03:01 PM
andrew's Avatar
-C-I-C-C-I Associate Member
Default Re: Seat adjustment
~ the lever (****) usually adjusts the vertical seat backs lower lumbar support... in the small of your back.
Old Oct 9, 2007 | 03:16 PM
CrossfireRSSS's Avatar
The lever on the lower side allows you to adjust seat up/down and back/forth. The **** on the upper inside of seat lets you lean the upper seat back/forth.
Old Oct 9, 2007 | 03:31 PM
andrew's Avatar
~ crossfirersss ... would indeed know this info ... for he has a base roadster.
my info was a guess.
Old Oct 9, 2007 | 06:49 PM
jhb's Avatar
jhb
I have the base coupe with those seats. Is it possible that the seat is in the fully "down and back positions"? Try lifting the lever and pulling up on the back of the seat.
Old Oct 9, 2007 | 08:28 PM
DAMNFINO's Avatar
While sitting in the seat pull the lever and shift your weight up or down, depending upon what position the seat is presently in. Plain and simple height adjustment, works with the use of "body english".
Old Oct 21, 2007 | 06:11 PM
huudoo's Avatar
my power seat on the driver side the adjustment
for where you lean the upper seat back/forth.
got stuck in the all the way forward after about 4 hrs finally got the back
back where it should be, man that sucked driving that thing tilted forward.
anybody had any issues with the seat sticking or seat motor going bad.
Old Oct 22, 2007 | 06:23 AM
BillP2R's Avatar
I wish this was correct.
For me, the lumbar support is too high. After several hours, it starts to bother me.
- Bill
Old Nov 27, 2009 | 08:42 PM
blackonblack's Avatar
I had the same problem as the original post. The handle wouldnt do anything when I had the seat slid back against the back wall. It was holding the seat in place. I moved it forward a few inches and wallah it worked. Sit in the seat, pull the lever up with your left hand (American car), and pull or push your body with your right hand grasping the steering wheel. I was so excited, I felt like I had just discovered plutonium for the first time.
Old Nov 27, 2009 | 08:54 PM
shapeshifter309's Avatar
I have the same problem. I've "adjusted" my weight, hell, I've gotten out of the car and lifted the seat while pulling on the lever, mine still doesn't do a damned thing.
Old Jul 18, 2010 | 01:41 AM
Joliet John's Avatar
Glad I found this forum. I've been wondering what the heck that lever was supposed to do. Nice that Chrysler didn't feel the need to even mention manual seats in the owner's manual. Rat bastards!
Old Jul 18, 2010 | 01:51 AM
Chrysler didn't build this car, but I get your drift.....lol
Old Jul 18, 2010 | 03:11 AM
phyrephlyte's Avatar
Can't have it both ways. I see you haven't been here long. Since a vocal majority/minority consider this an MB through and through, it would seem that Daimler didn't find it necessary to provide Chrysler with fully informative manuals on the cars it built for Chrysler in Europe.
When sorting through your ******* rats, you should not overlook those that were honorably concieved and born.
Good wishes,
PP
Valk
Jul 12, 2021 09:49 PM
steps
Apr 26, 2016 06:21 PM
2005 Ragtop
Oct 3, 2015 03:01 PM
atdavis2
Sep 21, 2015 01:25 PM
steps
Sep 19, 2015 10:43 PM
