Engine Stutter
Old Dec 20, 2007 | 09:30 AM
DarkSide41's Avatar
Default Engine Stutter
I may have searched for the wrong terms but I could not find any prior post . This doesn't seem to be a tranny issue but what do I know ? It only happens from a dead stop or very slow crawl when I get on the gas , very slow turns etc . The engine feels like it stutters for a few moments before it begins to go smoothly . I thought I may have selected the wrong fuel so I let it go down to the low fuel light and filled it with 93 octane , but it still does it . I noticed it when the temps here started dropping below 50 degrees and not sure if it does it after it warms up during the day . I've been stuck at work when it's pretty and warm I'm 4700 miles to my next service (45k) and unless it is a sign of something else more significant , I'll just wait until it gets to the dealer for that . Any ideas ?
Old Dec 20, 2007 | 10:17 AM
xfiredj's Avatar
Default Re: Engine Stutter
Very seldom...only a couple of times but it has happened to me too. Under 50 degrees and a slow turn or down a driveway...any thoughts out there?
Old Dec 20, 2007 | 02:09 PM
sonoronos's Avatar
Sounds like either a fueling or vacuum issue to me. Time to run an OBD scanner and datalog the tip-in and fuel enrichment along with the AFRs.
It's pretty rare to get knock in 1st gear from a stop. If it was knock, you'd be stumbling every time you go up a hill in high gear.
Not sure if this helps, but hopefully it does.
Old Dec 27, 2007 | 09:48 AM
UberXFire's Avatar
Smile Re: Engine Stutter
I had the same problem for about 3 months. A few trips to the dealership and they finally settled on a bad O2 sensor. I didn't like their service fee so I decided to replace it myself. Fortunately, I had to take it in for a TPMS reset and when they gave it back - no more O2 sensor problem.
I think they did enough resets of the ECM that whatever was out of tolerance was recalibrated.
Old Jan 8, 2008 | 08:57 AM
DarkSide41's Avatar
Thanks for the response . It does it every now and then so no big deal , I'll let them look at it when it's due for the next service and let my Ext warranty take care of it
It doesn't seem to matter what the temp is as I have noticed it occuring anywhere from 50-68 degrees when I pay attention anyway .
Old Jan 8, 2008 | 09:10 AM
apkano's Avatar
Life is random...so am I.
Have you tried the throttle reset/calibration procedure yet?
Old Jan 8, 2008 | 01:36 PM
ShawnQ's Avatar
Crank Position Sensor is a common problem you may look into as well - easy fix and reasonably priced part (not cheap, but a lot less than a dealer would charge).
Look at some of the common symptoms associated with it and you may be able to relate your issues with it.
SQ
janaiy
53
Nov 2, 2015 09:23 PM
crossfireusa
Oct 28, 2015 12:03 AM
RacerXofFL
Sep 15, 2015 05:00 PM
BEATv1
Sep 10, 2015 12:58 PM
MickeyNasty
Sep 6, 2015 08:29 PM
