Brake Light Activation Noise
Old Oct 23, 2008 | 08:54 AM
smokey847's Avatar
Default Brake Light Activation Noise
The last couple of days I've noticed a very subtle noise when I slightly apply the brake pedal. I backed up this morning and discovered the noise was some kind switch activating the actual brake lights to come on. I can best explain it as a "pop" or "tick." If you know how the turn signal sounds, the noise I'm hearing kind of sounds like the deeper, lower "tick" when the blinker is turned on (for lack of better explanation). I'm not really concerned; however, I've never heard it before and was curious to see if anybody else has noticed it.
Thanks for any response!
Old Oct 23, 2008 | 09:15 AM
Default Re: Brake Light Activation Noise
Not another noise thread. Turn up the radio and enjoy the ride.
Old Oct 23, 2008 | 09:31 AM
robby363's Avatar
Deleted................
Old Oct 23, 2008 | 10:11 AM
mouserider's Avatar
Are you sure you're not just hearing the switch that turns on the light that is mounted near the paddle?
Old Oct 23, 2008 | 10:18 AM
robby363's Avatar
Originally Posted by mouserider
Are you sure you're not just hearing the switch that turns on the light that is mounted near the peddle?
I should of read it a little better. I think your right that's what it sounds like now that I read his post again.
Old Oct 23, 2008 | 01:24 PM
smokey847's Avatar
Thanks everyone. I'm sure that's what it is but since I had never paid that much attention to it before, I wasn't sure if it was normal for that to be audible. Thanks for clearing it up.
Old Oct 24, 2008 | 08:48 AM
Goldwing's Avatar
Not uncommon for there to be squeaks from the pedal linkages. It's possible that the brake light switch, activated by the brake pedal depressing, it making a little click. I don't notice much of that with the top down on the roadster. A little WD40 or silicone spray works wonders on the linkages. I even hit all the rubber grommets and suspension linkages when I wash my rims.
PNA
Aug 30, 2024 02:06 PM
PNA
Nov 12, 2020 04:44 PM
PNA
Jul 27, 2015 12:28 PM
westonrose
Jul 14, 2015 11:25 PM
Blackout317
Jul 7, 2015 08:38 PM
