Oil leak
Old Nov 18, 2008 | 11:58 AM
glpatton's Avatar
Default Oil leak
Very new to the XF. Purchased a 2006 coupe limited in September with 13,000 miles for $14,000. A couple of weeks ago I noticed oil on the garage floor but only a few drops worth. Today there appeared to be more. Has anyone experienced an oil leak and if so where was it from? I'm wondering if the drain plug could be the problem. I have had oil pans distorted from over tightening on other cars and this caused the plug to leak. Any help would be appreciated. Thanks
Old Nov 18, 2008 | 01:40 PM
04Fire's Avatar
Default Re: Oil leak
I believe there have been a few on here that have had this... seems that a number of '06's have bad valve cover gaskets.
Do a search as I could be wrong
Old Nov 18, 2008 | 01:45 PM
ImportLabSRT's Avatar
Check the valve cover gaskets if its engine oil. If trans oil (red) the CHA connector going into the trans leaks often on all the 7226 equipt Benzs. We replace a dozen or so a week at the dealership.
Old Nov 18, 2008 | 02:22 PM
glpatton's Avatar
Thanks for the advise. It is engine oil for sure. I take it in tomorrow and I'll make sure they check the valve cover gaskets.
Old Nov 18, 2008 | 02:25 PM
tighed1's Avatar
I had oil seepage around my valve covers.
All it took for me was a quick tightening and all is well since then.
Old Nov 18, 2008 | 02:55 PM
CALL911's Avatar
Check to make sure the oil filter is not leaking! I just had this happen to me about three weeks ago. The after market filter I used, started to leak around the o-rings after about 5000 mi.
Old Nov 18, 2008 | 06:40 PM
Chris L.'s Avatar
There's a shield underneath, if the oil was changed & they were sloppy, there could just be residual droppings still coming off that shield.
Old Nov 19, 2008 | 02:39 AM
Mr. Max's Avatar
Yep, This is what happened to me I think. Had a leak I thought. Checked the stick and it was down. Topped it up and shazzam never happened again, not a spot! Mark right up to max. But as long as I have you here.
Wouldn't you think they could have found a better color for the end of a dipstick than brown. My Cad has that same reddish brown color on the tip. Is this some kind of practical joke by the engineers. My Jag's stick is white. Were these things white once? What gives?
Old Nov 19, 2008 | 04:57 AM
mika33's Avatar
Ha, ya... the way I have to really tell how low/high the oil is, is by taking a rag and wiping one side of the stick off (wiping orthogonal to the stick). But my car is a 2006 and I never had a problem with oil leak. There is a little oil around the valve cover, but it is definitely not losing any.
Old Nov 19, 2008 | 08:34 AM
glpatton's Avatar
Went to the dealer today and they said it was not an oil leak but a transmission leak. They said it looked like the pan was the cause of the leak. No parts in house so I take it back Monday. Anyone else experienced this type of leak?
Old Nov 19, 2008 | 10:56 AM
Iamfink2's Avatar
Make sure their aware of the TSB:
21-002-05 AUTOMATIC TRANSMISSION FLUID WEEPAGE 2005-01-14 because a lot of the mechanics don't know this car and they might just think its the pan leaking. Was the leak coming from the passenger side of the transmission? If it was it could be the TSB.
Old Nov 19, 2008 | 01:00 PM
Mr. Max's Avatar
Take this guys advice The Chrysler guys are just guessing most of the time. I'm not even sure my guys have a service manual. If they do they sure don't read it.
Old Nov 19, 2008 | 02:07 PM
glpatton's Avatar
Thanks guys. This site is worth it's weight in gold. I wrote down the TSB and will make sure they address it.
Old Nov 19, 2008 | 02:55 PM
Mr. Max's Avatar
Red face Re: Oil leak
ORTHOGONAL? GREAT WORD! From now on I will wipe my stick (no jokes now) ORTHOGONALLY. I will continue to wipe my a*s in a linear fashion (even I couldn't resist that set up)
Old Nov 19, 2008 | 03:39 PM
mika33's Avatar
By linear I will assume you meant "parallel"... I do not think anyone wipes in curvy/wavy arcs... or possibly even piecewise smooth curves... or something...
Old Nov 19, 2008 | 03:52 PM
RJ44130's Avatar
My 04 coupe was leaking, they thought it was the trans. pan but it was not. It was a connector. (covered under warranty).
Old Nov 19, 2008 | 04:01 PM
Mr. Max's Avatar
Talking Re: Oil leak
Well, If Einstein was right and space is curved... I wonder if space is more curved around a large a*s lol.
Old Nov 19, 2008 | 04:12 PM
mika33's Avatar
Well, If Einstein was right and space is curved. I wonder if space is more curved around a large a*s lol.
You must be "packin" loool
Old Nov 20, 2008 | 06:04 PM
FTroopChief's Avatar
Welcome, sounds lik a good buy..Let me tell you about my horror story..I purchased my 2005 Ltd Cpe with 17,400 miles. I took it for an oil and filter and schedule A service at a very reputableMercedes Dealer in Boerne, TX. They did an excellent service, complete underside inspection, measured my brake pads, etc etc. Informed me of a small oil leak around the oil sensor housing, and suggested because the car was under warranty, to take it to a Chrysler Dealership. This I did and thei "certified" Crossfire, Viper and Prowler mechanic proceeded to crack the lower oil pan while removing it with a brass machinist's hammer. The sensor was replaced, as was the 8 quarts of Mob ! that was just put in. Said it's ready come and get it. I "got it" alright and drove home. Parked in the garage over night and next morning backed the car out (see picture) and left 8 quarts of Mob 1 on the garage floor and driveway.Really, really, realy bad experience. Took a week in the shop to get a new pan on and 8 more quarts of Mob 1, no charge to me except for Librium. Moral is, know your dealer and service manager, check credentials of "certified Mechanic", inspect car before an after maintenance, demand fender blankets which should be a given, Drive car and park on a clean surface for a couple hours and check for leaks after. If you have problems and you're not satisified, go up the ladder and talk to the owner. So my first oil change took 24 quarts of Mob 1.
John P
FTroopChief
TerryR
Dec 13, 2019 03:27 PM
minimayhem
16
Aug 23, 2016 07:47 AM
Oct 1, 2015 01:42 AM
Sep 28, 2015 07:40 PM
stlas69
Sep 14, 2015 06:45 PM
