Can't find a thread... Please help me out.
Old Dec 3, 2008 | 01:17 PM
BlackBeauty's Avatar
Default Can't find a thread... Please help me out.
I can not find the thread that this was discussed. Please either point me to the thread or answer my question.
I have a 2004 Crossfire.
Went and strarted it for work this morning and the wing came up the wing light was flashing, the abs light was on, the bas esp light was on and i have no traction control. I can do donuts all day long. Please help me in diagnosing this.
Old Dec 3, 2008 | 01:36 PM
Stogey's Avatar
Default Re: Can't find a thread... Please help me out.
Sounds like a speed sensor issue, rather than taking a guess, I would take it to a shop that can download the at fault information from the computer.
Just my Dos Centavos
This one?
https://www.crossfireforum.org/forum...light+flashing
Old Dec 4, 2008 | 02:53 AM
crossfirefun's Avatar
Check your battery connections and voltage before starting. It is a known problem for the wing to go up while starting if the battery is getting weak.
Old Dec 4, 2008 | 03:20 AM
patpur's Avatar
Senior Member/Moderator
Did you try the reset in your manual? I will find it and post the page number for you. It involves turning the steering wheel from all the way right to all the way left. I had the same issue twice. I will tell you after I did the reset it took my car a few hours to reset itself. The problem has no happened since.
I think the battery issue just affects the spoiler, the issue I'm talking about the BAS/ESP warning comes on and the spoiler goes up and you can't put it down. The same thing happened to our Mercedes and it was the steering angle sensor that was pulling the code. I'll get back on here with the page info this morning for you unless someone provides it sooner.
Pat
Old Dec 4, 2008 | 07:32 AM
04Fire's Avatar
Originally Posted by Stogey
Sounds like a speed sensor issue, ...
BINGO.....
Old Dec 4, 2008 | 08:24 AM
now that is service...doesn't get any better than that, now if Chrysler's service depts could do that???
Old Dec 4, 2008 | 08:32 AM
patpur's Avatar
Check page 88 of your owners manual. That tells you how to Synchronize your BAS/ESP system. If that does not work and it may take a few hrs to reset, mine did, then you have most likely got a steering angle sensor problem.
Hope this helps, please let us know how you make out.
Thanks - Pat
Old Dec 4, 2008 | 04:59 PM
I will keep you updated. I will try the reset tomorrow. But as of now it is going to the dealer for service monday. I figure i will get the steering dampener checked the radio replaced and the rear suspension squeek tsb taken care of. Where can i find the tsbs so i can write a list...
Old Dec 4, 2008 | 05:05 PM
nevermind about the tsb's i am stupid
xfireohio
Jul 20, 2020 12:03 AM
Buchacho
Aug 21, 2015 04:56 PM
Vazgen
Aug 11, 2015 01:24 PM
Aug 4, 2015 04:57 PM
onehundred80
Aug 2, 2015 11:37 AM
