Oil change
Old May 21, 2009 | 01:55 PM
rem-lor's Avatar
Smile Oil change
Hi everyone..
I dont know if this is somewhere else one the forum.
i just thought I would ask this anyway as I'm in a hurry right now.
Basically my brother and I did the oil change on the Crossfire (2004).
I was wondering how I can reset the maintenance indicator on the dash.
The one that informs you on when to get the oil change.It has a little wrench with a number letting you know
when to change the oil,/get it serviced.
Right now my indicator is at -900 miles which is really anoying...
Thanks for your help guys.
Lee
Old May 21, 2009 | 02:05 PM
danimal's Avatar
Default Re: Oil change
Just type FSS in the search box and take your pick from the results.
Old May 21, 2009 | 06:04 PM
magneticred's Avatar
From the owners manual page 114:
1. Turn key to the ON/RUN position.
2. Within one second press the ****/button twice.
3. The present status for days or distance is displayed.
Within 10 seconds turn the key to OFF/
LOCK.
4. Press and hold the ****/button, while turning
the key to ON/RUN again. The present status for
days or distance is displayed once more. Continue
to hold the ****/button.
After approximately 10 seconds, a signal sounds and
the display shows 7,000 miles (Canada: 11,000 km) for
approximately 10 seconds.
5. Release the ****/button.
It worked the first time for me, but I understand that sometimes - if it doesn't work - it has to be repeated.
Old May 21, 2009 | 08:22 PM
rem-lor's Avatar
thanks so much.
It worked!
Old May 22, 2009 | 01:02 PM
Pizzle's Avatar
I have tried for almost 2 years to reset this thing and followed the instructions to a tee. I have even deviated thinking I was doing something wrong. All I ever end up doing is resetting the odometer. Here is a pic of my dash.
LOCK.
Old May 22, 2009 | 03:28 PM
ZAHANMA's Avatar
Wait, you've been trying to reset it for two years and you are only 730miles over the suggested service schedule... thats impressive.
Old May 23, 2009 | 09:58 AM
Pizzle's Avatar
Yep, been at 730 for the whole time. Kind of my point. Can't reset and it never changes.
Old May 23, 2009 | 10:22 AM
vipr1ab's Avatar
I don't think the Germans could have made the process any more complicated.
Pizzle, it sounds like something might be broken.
Old May 23, 2009 | 10:52 AM
Hawk Monster's Avatar
This may sound kinda crazy but here goes. If it is NOT broken, your dealer can use their computer to reset the FSS. I guess if it drives you crazy it might be worth a shot.
Old May 24, 2009 | 09:25 AM
donmcd's Avatar
I had trouble with this also. Tried several times. Finally, after getting the
current status displayed, I pressed the **** while tuning the key off and
continued pressing while runing key on. After a few seconds, it reset to
7000.
Old May 24, 2009 | 09:32 AM
MikeR's Avatar
This is probably the DAYS past due, not miles. My original NA was -3xx when I bought it and it clicked over 1 every day until I reset it. You probably have maxed out the counter. 365 x 2 = 730, two years.
Old May 24, 2009 | 09:52 AM
ppro's Avatar
The instructions must be followed to a T. The first time I tried to do it, I had to try several times and it never worked. I printed out the instructions, had my kid read them to me as I went, and I finally got it right.
The second time I did it, it worked first try. There is no forgiveness. And mine too had the same number (-730) until I got it right.
The thing I can't get to work is the test to see the state of the oil (it's supposed to give a reading). The instructions say that if it doesn't work it's a malfunction... I have a feeling that feature is flaky right out of the box.
minimayhem
16
Aug 23, 2016 07:47 AM
csteve0355
Sep 23, 2015 05:57 PM
lazorouss
Sep 11, 2015 09:16 AM
MickeyNasty
Sep 6, 2015 08:29 PM
PNA
Sep 5, 2015 02:20 PM
