Car in shut down mode
Old Jun 19, 2009 | 08:09 PM
Urban Crossxf's Avatar
Default Car in shut down mode
Need help
I've read most of the posts on what to do if your car does not start or starts for 2 secs and then shuts off. I was lucky the first time it would not start and was able to drive it home. Now it will not start
  1. 1. Replace relay module or fuel relay module 2. Replace crankshaft sensor. 3. disconnect battery cable so system could reset.
I thought the problem would be the relay control module so I went out purchased a new one, installed it and car still would not start. Then I purchased the crankshaft sensor but did not installed it because I had remembered my mechanic had taken off the tire before I came home and he said it triggered the alarm. Question? Would it cause any problems if I disconnected the battery cable even though I installed a new module?
I have not driven it since Sunday June 14th. thanks
Old Jun 19, 2009 | 08:27 PM
danimal's Avatar
Default Re: Car in shut down mode
Disconnect the battery for 15 - 20 minutes and hook it back up. It should not create any problem...and may just clear up a few. Hope the module was your problem. Try it and let us know the outcome.
Old Jun 19, 2009 | 08:50 PM
thanks for the reply..
should i disconnect both cables or just the negative one
Old Jun 19, 2009 | 08:52 PM
rfontham's Avatar
Security issue? There is a dash button on my limited to turn off in tha event of a Tow. It Deactivates the alarm. Yours may have thought it was being lifted and shut down. Check the manuel.
Old Jun 20, 2009 | 02:35 PM
Default Re: Car in shut down mode UPDATE!!!!
Well...i disconnected both cables probably about for 10mins car almost started but went dead again. Clock shows 12:00. We checked the battery and its charging good. I will disconnect it once again and wait at least 20 min. or more. Also the panic button should work after all is reset even if the car does not start right!!!!. I do have a crankshaft sensor on standby just in case none if this works. wish me luck. I need it to go to work on Monday.
Old Jun 20, 2009 | 02:58 PM
Mimi05SRT6's Avatar
If it's the original battery, you may need a new one....Good luck!
Old Jun 20, 2009 | 03:36 PM
It's the same one from the day i purchased it Feb 2008. It was connected to meter and read ok. Any waited and hour this time..clock did reset panic button working now. but when it starts and shuts down immediately.
Does the Crankshaft Sensor need to show a code before it goes out. or can it just fail without showing a code.
stressing just a little now
Old Jun 20, 2009 | 04:18 PM
Tim2739's Avatar
A friend had a simular problem with a Chrysler Aspen. There is a security sensor in the key remote and they changed to their spare key and it worked fine. It might be worth a try.
Old Jun 20, 2009 | 05:16 PM
Thanks Tim...worth a try ..Might have to call McGyver.(old tv show)
Old Jun 20, 2009 | 11:50 PM
Spare Key did not work...Called a Mobile Tech. that has a computer and will search and hopefully find the problem and clean the codes. I will keep everyone posted thanks for the support as usual.
Old Jun 22, 2009 | 09:25 PM
Default Re: Car in shut down mode Update 2/possible time problem
Hey guys thanks for all the support really appreciate everyone helping out with suggestions.
Heres the update
Replaced Relay moudule
crankshaft sensor
new interstate battery
Still not starting tries to start and shuts down
will be getting a camshaft sensor module Tuesday
If the camshaft sensor does not start the car I was told that the only thing left is the timing is out of sync. and they have to take apart the engine and manually reset the time. I've never heard such a thing. Has this happened to anyone in this forum. Any suggest would help
Old Jun 29, 2009 | 09:10 PM
Off to the dealership she went ...tech said about 5-7 days for computer module gone bad will replace it free. Some kind of Fed Emissions Law would have cost $1700. But will let you great folks know when i'm up and running again. Thanks for all the help/support greatest forum ever.
mhajek18
Dec 30, 2015 03:40 PM
autumnmass
Jul 2, 2015 10:35 PM
rancher1983
Jul 2, 2015 08:09 PM
gtjl
Jun 10, 2015 02:44 PM
blackpepper
16
Jun 2, 2015 12:50 PM
