Anyone checked their mileage?
Old Dec 14, 2003 | 10:50 AM
CCrossfire's Avatar
Default Anyone checked their mileage?
I'm still working on my dealer supplied full tank of 93 octane, and with over 200 miles I am still showing 1/2 tank. Chrysler says 21 city, 28 highway and I have been putting on mostly highway miles, but so far mileage looks as if it should be good. Also mileage usually increases as the engine is worn in, so I'm pretty pleased.
Old Dec 14, 2003 | 10:53 AM
MARK_UK's Avatar
Default
Sorry but I don't believe you
Old Dec 14, 2003 | 11:54 AM
lordpercy's Avatar
Default mpg
i'm getting about 20 around town (london) and 25 on motorway work
Old Dec 14, 2003 | 11:56 AM
WesMichaels's Avatar
Default
I've got 3,125 miles on mine. My usual driving is a mix of city and interstate. I'm getting right at 23mpg. And I still like sticking my foot in it to hear the pipes in first and second gear. I did take a long intersate trip about 1,000 miles ago and I got 27.2 mgp highway. I'm happy as can be. Much better mileage than I get with my 4.0l Explorer.
Old Dec 14, 2003 | 02:38 PM
CCrossfire's Avatar
Default
Believe it Mark, just checked my odometer, shows 232 miles, had 29 on it when I bought it (my test drive) and they filled it up. Guage shows just above 1/2 tank. I must admit, I have not hot-rodded this car and won't until I have a few more miles on it. Real pleasant result considering my previous ride. Best regards - Bob
Old Dec 14, 2003 | 03:28 PM
kusheen
Guest
Posts: n/a
Default that's great!
You must've accidentally gotten the electric/gas hybrid prototype they intend to release in 2005...
Old Dec 14, 2003 | 04:58 PM
CCrossfire's Avatar
Default
Nope, got the V6 stuck under there. I can't vouch for the accuracy of the guage though, I may need a push on my way to the gas station. Takes 15.1 gallons, will post an update when I fill-up.
Old Dec 14, 2003 | 05:23 PM
Default
The only thing I've done is install K&N filters.
Old Dec 15, 2003 | 10:00 AM
willie's Avatar
Default
I have over 7000 miles and do a mix of city / highway mostly hiwhway and get at least 25 mpg on road trips I have been getting 27 - 28 mpg. The gauge is funny the 2nd half of the tank seems to disappear faster than the 1st half
Old Dec 15, 2003 | 11:24 AM
Default
Almost every car I've ever owned had a fuel gauge that the first half tank went a lot slower than the second half. Keep in mind cars us a float type variable resistor type transmitter. Not as accurate as the dialectric type that are used in aircratf, which are much more accurate.
Old Dec 15, 2003 | 01:01 PM
CCrossfire's Avatar
Default
The non-linear Crossfire quage should be designed to compensate. I want to fill-up when the guage indicates exactly one half empty and see if it takes 8 gallons. (15.9 gallon tank - my error previously describing it as 15.1)
Old Dec 15, 2003 | 01:30 PM
Reg Kittrelle's Avatar
Default
My second tankfull showed a fuel-burning rate of 24.6 mpg; a mix of freeway and city.
Old Dec 15, 2003 | 01:34 PM
Default
That's pretty much in the ballpark with what I'm getting.
Old Dec 15, 2003 | 02:46 PM
macjake's Avatar
Default
Just filled up about 5 miles after orange light came on, 5/6 of a tank 238miles-10.5 (uk) gallons or 12.5 (usa)
=23mpg (uk) = 19mpg (usa)
mainly commuting 40 mile round trips
Old Dec 15, 2003 | 03:37 PM
Gailwrath's Avatar
Default
I have 4700 miles on the car. Just filled up, this time I got 21.38mpg. I must confess I do have a lead foot and commute over a moutain every day. i think the best i have seen ( on my car is about 27 ) if i dont use the auto shifter and stay under 80.
Old Dec 15, 2003 | 06:40 PM
sambo13's Avatar
Default
Just returned from an 8000 mile trip around the US. Crossfire ran great, tires are OK, got about 27 miles per. Turned a lot of heads on the trip, even in Las Vegas. Only problem was tire inflation light kept going on on cold days. All this car needs is a little more horsepower, then it would be perfect. I wish DC would come out with a upgrade.
Old Dec 16, 2003 | 12:09 PM
Default
sambo 13: Just as I drove the car off the lot the tie inflation lite came on. Drove around the block and back to the service area. The right rear tire was about 4 lbs shy of spec. Filled to spec, and the lite went out, nev3r to return. However, that 4 lbs does not fall within the lite's specc so I think it was coincidental. Anyone else have this lite issue?
Old Dec 16, 2003 | 12:16 PM
Default
Mine came on once. Caused by a punctured left rear tire. Tire was repaired and lite has been off ever since. I do check my tires when I wash the car (once or twice a week) and adjust the pressure as needed. I have a compressor w/ 25 gallon tank in my garage. Makes airing tires very convenient.
Old Dec 16, 2003 | 12:25 PM
VegasCrossfire's Avatar
Default
Wow!!! 8000 mile trip - awsome!!! How long did that take :?: Too bad you didn't let us know you were coming to Vegas - we would have met you on the Strip and really turned heads!!!
Old Dec 16, 2003 | 05:24 PM
sambo13's Avatar
Default
VegasCrossfire,
Trip took 5 weeks. Lots of side trips and stops along the way. I should have posted my trip, too late now. Seeing 2 Crossfires together would have pushed everyone over the edge. I'm going back in August. I'm trying to rent a condo for 4 months, I want to see if I can give up Florida and move permanently.
Sambo13
