AC sight glass
Old Jul 11, 2010 | 07:12 PM
elfprofessor's Avatar
Default AC sight glass
My aC needs topping up and cannot locate the sight glass. Any hints as to where it is located? Thanks
Old Jul 11, 2010 | 07:16 PM
Default Re: AC sight glass
If mine has one, I haven't come across it yet. Most cars today do not use them anymore. The manufacturer wants you to retrieve, recycle, then refill with proper amount.
James
Old Jul 11, 2010 | 07:26 PM
Thanks James, however my 09 Prius has one and I thought all cars did likewise. I guess I may have to gauge the amount of necessary freon by the gauge on the refill container.
Old Jul 11, 2010 | 08:31 PM
waldig's Avatar
Talking Re: AC sight glass
If your doing it safely you take the suction pressure and the line temp into consideration to calculate the SUPER HEAT. That should be about 10 degrees F as a start point and subject to change due to DA and temp.
It is also good to have a BIGGY fan on the radiator to get real world conditions, idling is not good for testing typically.
The high pressure will assist in the proper charging and most KITS dont have more than a low pressure gauge. Over charging can cause the safety to pop off or vent.
It is critically important that you dont rush the addition of freon to the compressor. Never turn the can over to allow liquid into the compressor. you can Chill-break the compressor valves doing fatal damage to the compressor. FYI
W DY
Old Jul 11, 2010 | 09:53 PM
Montana Crossfire's Avatar
No site glass.
By the way, did you actually say Prius on this forum?????
Montana
PNA
Nov 12, 2020 04:44 PM
gp1200x
Dec 6, 2015 12:59 PM
RedNeck
Sep 4, 2015 09:54 PM
flame
Aug 19, 2015 04:06 PM
Abaton6
Aug 16, 2015 12:55 PM
