water leak, wet headliner
Old Oct 26, 2010 | 02:25 PM
brewski's Avatar
Default water leak, wet headliner
I have a water leak. After a heavy rain the headliner is wet just behind the drivers seat. any ideas?
Old Oct 26, 2010 | 04:57 PM
bluecoupe's Avatar
Default Re: water leak, wet headliner
Lift the rear hatch door and check the rubber boot at the top of the opening, the one for the wiring pass through.
Old Oct 26, 2010 | 05:20 PM
I hope it is not a Black car, or we will never hear the end to it....
Old Oct 27, 2010 | 03:56 AM
kingkub57's Avatar
If the leak is showing up on your headliner just behind your head area then it could be a bad seal on the body where the door glass makes contact, or may even could be in the roof rail area under it, the seal may have cracked due to body stress. When mine did it, it was the door glass/body seal, and it took over 4 times to fix it at the dealer under warranty it was an 04 coupe. Hope this helps.
minimayhem
16
Aug 23, 2016 07:47 AM
onehundred80
Aug 6, 2016 12:03 PM
csteve0355
Sep 23, 2015 05:57 PM
RacerXofFL
Sep 15, 2015 05:00 PM
williammt
Sep 6, 2015 11:23 AM
