new h&r 12mm spacers
Andrew, how did you gets two inches out of the lowering? Mine goes in this week for the Eibach springs and they claim 1.2 inches of lowering both front and back. Did the Koni's take it down a little more?
Also spoke with my suspension shop and Eibach states that the factory shocks are just fine, no need to upgrade unless you want to.
P.S. Still debating on the spacers. My guy at the suspension shop wants to take a close look at the wheel configuration before offering his advice on the spacers. I like the idea of moving the wheel out to fill the well but want to make sure there won't be any unusual side effects. Have you experienced any problems at all with the lowering and spacers?
Originally Posted by HDDP
Andrew:
Do you have the product # and bolt length for the 10mm/12mm spacers ?
You're help is again appreciated
hope this helps! :wink:
Andrew,
Do you know the weight of the spacers? I'm trying to lighten my XF to increase its performance. That includes me going on a diet.
It does look fantastic. Do you have any worries that the body will rub against the tyre?
Originally Posted by english_bob
Andrew,
Originally Posted by typhoon55
How easy / difficult to install wheel spacers? Did you order online? for some reason i can't see your pics -
i ordered mine through: tc kline racing 614.771.7744 (ask for pete). they are located in ohio.
i have corrected the files. pics without & with spacers.
the reason i recommend 10mm in the front is...any larger of a spacer would push the rim past the top of the wheel well lip.
the rear looks best with a 12mm spacer imo...some are going larger in the rear but i don't like how the rear tire sticks out so far from a rear view. (max in the rear would be 15mm)
i'm not into pimp'n my ride.
i want a clean look and an aggressive stance.
hope this helps!
without spacers:
with spacers:
hope this helps!
without spacers:
with spacers:
maxcichon
May 14, 2019 07:30 PM
grip grip
31
Sep 27, 2015 10:06 PM
04Fire
Sep 15, 2015 07:40 PM
