clutch sticky
Old Dec 2, 2011 | 09:41 AM
05CrossfireCid's Avatar
Default clutch sticky
If im really hard on the car and clutch, it will start having the clutch come up real slow due to the master cylinder making it go up slow and it pisses me off especially when my friends and i r racin around it will start getting stiff and coming up slow. does any one know how to delete it or if theres a part i can by to make the clutch not have a clutch saver?????
Old Dec 3, 2011 | 11:39 AM
downwardspiral's Avatar
Default Re: clutch sticky
stop using the clutch
Old Dec 7, 2011 | 11:44 AM
Goldwing's Avatar
Yeah, get one of those screen door springs and attach it to the top of the clutch pedal and the bottom of your dashboard.
Old Dec 14, 2011 | 01:07 PM
HelotesKris's Avatar
not to sound like a ****, but if you shift correctly and not grind your gears or let the clutch slip it wont do that, you can still shift fast and race around. I have an 05 6 speed, and the clutch replacement with a new master cyl and flywheel re surface was $2100 so be easy on you clutch cause it will cost you, it already sounds like you have worn the clutch considerably and probably have some nice hot spots on the flywheel.
tcar32909
Aug 1, 2024 02:41 PM
jhansen
21
Feb 15, 2017 04:26 PM
waldig
Aug 24, 2015 10:40 PM
needfreetime
Aug 1, 2015 07:06 PM
ricardo 53
Jul 21, 2015 07:49 AM
