Will these rims fit our car???!!!
Re: Will these rims fir out car???!!!!
They will not fit! Not without some work, at least. He says the offset is 8 or 9... thats wrong. The offset is probably in the low 30s.
BMW uses a 5 x 120 bolt circle and has a 72.5 mm center bore.
To make them fit you would need a hubcentric adapter. This would convert our 5 x 112 to 120 and ensure a tight fitment.The adapter will likely be about 15mm thick which would put the effective offset in the high teens which is too low on XFs.
If you rolled the fender you MAY be able to make it work.
My advise is to pass these up, there are plenty of options out there that wont be as much of a headache.
thank you to the both of you for your help.
Hey,
Here are similar rims that should work, 5x112 35 offset.
GetYourWheels.com: Stance Wheels Stance VIP Evolution Matte Black Machined with Stainless Stee Chrome Lip Wheels : Wheel and Tire Packages|Staggered Wheels|Custom Wheels|Luxury Rims
Not cheap though.
Not cheap though.
Hey,
Not cheap though.
Not cheap though.
rayth
41
07-31-2019 04:02 PM
mhajek18
12-30-2015 03:40 PM
