Overheating problem HELP
Old Jul 19, 2004 | 08:29 PM
Ed's Avatar
Ed
Default Overheating problem HELP
Is anyone having or had a prblem with overheating?? My son after seeing my Crossfire, went out and bought one. Now he is having an overheating problem that his dealer does not know for sure what the problem is. They have decided to replace the computer, however it sounds like that is a guess at the problem. Also, they are having problems getting the new computer. -- I appreciate any input. -- Thanks Ed :?: :cry:
Old Jul 19, 2004 | 09:40 PM
Mo_Bandy's Avatar
Default
Ed,
I was running my car through the mountains in 100 degree weather, with the air on and the needle did not budge from the middle line...
You may want to check to be sure that the fan connection is ok.. That's what it sounds like...
Hope this helps MO
Old Jul 20, 2004 | 12:36 AM
dirtboy's Avatar
Default
Sometimes my needle is a little above the line and other times it is a little below the line. Is that normal?
Old Jul 20, 2004 | 01:23 PM
XfireAce's Avatar
Default
My needle does the same thing dirtboy...is yours manual? Mine is...
ACE
Old Jul 20, 2004 | 04:56 PM
dirtboy's Avatar
Default
Yep, mine is a manual. Sometimes the needle is dead center, but I don't pay much attention to it anymore. I thought it was because it is rather hot where I live, but now I think it is just how the car is.
Old Jul 20, 2004 | 07:06 PM
Ed's Avatar
Ed
Default
Mo_Bandy: Thanks for the response, I would think the dealer has looked at the area you suggest. They seem to "not know" and are willing to replace the computer just to see if that will fix it. -- Thanks again -- ED :roll:
Old Sep 6, 2005 | 06:02 AM
2005SilverRoadsterLTD's Avatar
Default Re: Overheating problem HELP
My step-dad had the same problem with the auto and it was the fan.
Old Sep 6, 2005 | 09:35 PM
Cobra953's Avatar
I have to agree with the above post...sounds as if the fan(s) are not coming on. This may be a simple sensor problem, rather then the computer. I had a similar problem in a VW. You may want to ask an MB dealer to take a look at it, they may be familiar with the problem. I had to take a Pontiac to a Buick dealer (Buick engine and transmission) in order to get a tranny problem fixed.
I was in traffic today on the Interstate, 103 degrees, a/c on, and no hint of overheating. The needle was just barely above the center line and remained steady.
Good luck, I know it is frustrating.
John
Old Sep 6, 2005 | 09:43 PM
CrossfireLTD's Avatar
Thumbs up Re: Overheating problem HELP
No overheating problems on my Roadster Ltd, needle is slightly below at times and slightly above (by a hair) on very hot days. In the cooler months its always dead center.
Old Sep 9, 2005 | 09:41 PM
BullFrog's Avatar
I've had two crossfire's overheat and the cause on both was always the exact same thing a failed cooling fan. The failure rate on the MB 3.2 engine cooling fan is high from experience and they squeak to get your attention that they are about to go, once they replaced the cooling fan problem was fixed and the coolant light went out.
What computer are you talking about to solve a over heating problem??? Don't tell them to look where they are not supposed to, have them replace the cooling fan.
tcar32909
Aug 1, 2024 02:41 PM
eikon
Sep 9, 2019 10:16 PM
jimf
Oct 10, 2015 10:22 AM
Abaton6
Sep 24, 2015 10:14 PM
Den656
Sep 23, 2015 12:27 PM
