CPS Failed? Which one do I buy?
Hi All,
I believe my CPS has failed in my limited 04 (crank but no start when i turn the key!). I did manage to get it started using a clutch start :) so if you are ever stuck this will work. I need help in purchasing the right CPS module, I need to know if I am ordering the latest bosch OEM part number as I understand there have been a few releases of this part? so I want to ensure I am getting the latest revision and best brand, bosch right? I found it available at needswings, but it is the hella OEM brand does anyone know if this is good, or should i stick with bosch? Crank Position Sensor and I found this on eBay, is this the right quality part? part number for this is 0261210170 < is that latest revision? Mercedes-Benz Crankshaft Position Sensor - BOSCH - 0261210170 - NEW OEM MB Crank | eBay |
Re: CPS Failed? Which one do I buy?
Mercedes-Benz Crankshaft Position Sensor - BOSCH - 0261210170 0031532728 | eBay
Is this guy selling original genuine bosch? |
Originally Posted by dom03
(Post 731921)
Hi All,
I believe my CPS has failed in my limited 04 (crank but no start when i turn the key!). I did manage to get it started using a clutch start :) so if you are ever stuck this will work. I need help in purchasing the right CPS module, I need to know if I am ordering the latest bosch OEM part number as I understand there have been a few releases of this part? so I want to ensure I am getting the latest revision and best brand, bosch right? I found it available at needswings, but it is the hella OEM brand does anyone know if this is good, or should i stick with bosch? Crank Position Sensor and I found this on eBay, is this the right quality part? part number for this is 0261210170 < is that latest revision? Mercedes-Benz Crankshaft Position Sensor - BOSCH - 0261210170 - NEW OEM MB Crank | eBay Go Bosch or walk home |
(Post 731921)
(Post 731926)
Is this guy selling original genuine bosch? https://www.autohausaz.com/search/pr...ition%20Sensor I haven't had to use it yet, but it's a Bosch and a bit less than the Ebay site. RL |
here u go this is where i ordered mine when my CPS failed. Genuine Bosch part.
Originally Posted by God_Likes_Tebow
(Post 731948)
Bosch 0261210170 Crank Position Sensor : Amazon.com : Automotive |
Originally Posted by RL67037
(Post 731946)
I bought mine here:
https://www.autohausaz.com/search/pr...ition%20Sensor I haven't had to use it yet, but it's a Bosch and a bit less than the Ebay site. RL I have gone ahead and ordered it from germanautosupply on eBay as he seems to carry genuine bosch, he offered to ship it for $25 via USPS Priority to Australia, so $70 delivered not bad! Mercedes-Benz Crankshaft Position Sensor - BOSCH - 0261210170 - NEW OEM MB Crank | eBay |
(Post 731934)
Not sure how that helped...
(Post 731954)
Well if you are stuck and can't start your car, you can clutch start it to get it started and then drive home... rather do that than pay $200 to tow it home!
a. the clutch wears out b. you run out of hill c. your pusher runs out of gas AND IT STILL WON'T FIRE !!!! 2. Not that many Crossfires WITH a clutch - most are 5 sp autos. |
