Acrid smell at high speed/RPM
Hi, just thought I would get some suggestiosn on this minor problem. The X-Fire I got with 100 miles on it, but noticed that there was an acrid/chemical smell when I 'pushed it' a little, say around 90 MPH or 4 RPM's. Was told it would go away, but am now at 6,000 miles. I brought it up during my first check up, and was told that since Chrysler couldn't drive the car faster than 60 MPH during their check ups, they couldn't confirm it. It's more an annoyance than anything, but if I'm going at a speed that tests the car, I'd rather not have to have the smell. Any suggestions? Perhaps if I knew what was causing it, CHrysler would fix it with out having to test it.
Re: Acrid smell at high speed/RPM
Do you mean the rotten egg smell?
Plus a bit more information... do you get the smell when you are going 90, or is it just after you've gone 90? How long does the smell last? Where does it seem like the smell is coming from? Is it worse or better with the windows down/up?
Jesus, it's like I'm some sort of CSI (you know Crossfire Symptom Investigator)
if you are getting a "rotten egg" odor only while under heavy acceleration it is most likely caused by a higher sulfur content in the fuel you are using. i experienced this problem while using crown brand gasoline in my crossfire. i haven't noticed the problem recently while using other fuels such as shell. here's a link to a tsb issued by toyota:
http://www.autosafety.org/Toyota%20S...l%20Models.pdf
Well, my major complaint really is fuel economy, I'm getting on average 19, ranges between 17, lowest, and 21 highest....(It's supposed to get 21 city, 28 highway) Maybe I should switch to Shell? I was going to send another thread on this issue. However, I do not believe the brand of fuel is the problem for this issue.
With respect to the first comment, I notice it with the windows closed, and usually when I'm accelerating and about a minute thereafter. It's been 4 months, and 6000 miles, so its gone through its breaking in period in my opinoin.
i tend to get around 22 mpg combined mileage in mine. that's without trying to be as easy on the accelerator as i would if i were not having any fun at all. i recorded 25 mph on interstate driving at around 70-75 mph when it was new. that mileage should improve since the car has a few thousand miles on it now.
many, if not most drivers today are not getting the epa estimated mileage in their vehicles. there are a variety of reasons, some of which include personal driving habits. but also the test methodology used by the epa isn't necessarily representative of city or highway driving. for example, in real city traffic you might wait 3 minutes at a light. the epa doesn't simulate such long stops. instead, the stops are much shorter, and the average speed is 21.2 mph. the city profile also includes a brief top speed of close to 60 mph. these factors are not typical of what you'll find driving in congested urban areas. so, it might be hard to achieve the rated city mileage.
for calculating highway mileage, we usually think of interstate driving at 65mph (or more). in the epa's dynamometer test for highway mileage, the vehicle never goes over 60 mph, and averages just 48.3 mph, and includes an initial vehicle start and ends with a stop. if you're driving down the highway at more than 65 mph it may be impossible to achieve the highway estimates as well. keep in mind that that the crossfire's good looks are for aesthetics; the high drag coefficient will kill your mileage at high speeds.
also, note that for the tests the ac is off!!!
here you go:
http://www.fueleconomy.gov/feg/fe_test_schedules.shtml
here you go:
jlseagull,
you live in MD, right? i live near baltimore. here's what you can do. drop your crossfire off at my house and let me drive a couple hundred miles in your car to see what kind of mileage i can get. mine's been sitting the last couple weeks since i put her on a no salt diet.
It seems like the problem with the smell (and perhaps the fuel economy) happens with my type of car, the Graphite X-Fire 6 speed. Certainly the last two commenters had the same type car as myself. Any comments?
