MAP or MAF?
Old 08-17-2017, 02:31 PM
crymar's Avatar
Default MAP or MAF?
Does my 2004 NA coupe have a MAP or MAF sensor, or both? I've been reading the posts, but can't seem to find a definitive answer. Would like some authoritative information. Thanks.
Old 08-17-2017, 02:48 PM
crymar's Avatar
Default Re: MAP or MAF?
Just did some research and found that my car has both. Should have done this before I posted. A little quick on the trigger finger.
Old 08-17-2017, 05:56 PM
The MAF is atop the throttle body.
The MAP is next to the Cam Position Sensor.
Old 08-27-2017, 01:07 PM
Always good to read about these things. I usually don't get into the car unless there is a problem so the information you just gave is a good thing or a good question. As familiar I am with this car I didn't realize it had both. I work on so many different makes and they are all different. In some cases the MAF sensor is so critical on a car it affects the way the transmission shifts...another learning experience which I am always happy to find out.
