'04 crossfire key not turn to crank car, wiggled steering wheel it cranked, now can't
04 crossfire key will not turn ignition, i wiggled steering wheel to lock then lift and key work..now cant move wheel nor key will not turn.
Re: 04 crossfire ltd key not turn to crank car, wiggled steering wheel it cranked, no
Originally Posted by Yvonne
(Post 898351)
CLICK |
Re: '04 crossfire key not turn to crank car, wiggled steering wheel it cranked, now c
(Post 898351)
Your "sticky key" is an "age old" problem common with the first couple of model years, & well documented here with excellent instruction, as onehundred80 posted. Repair or replacement are both options. If you're not a do it yourselfer, your best bet may be an honest, Independent repair shop specialized/experienced with Mercedes/German cars. |
Also if you take it to an independent, it wouldn't hurt to take them the repair instructions in onehundred80s link. I suggest printing the out.
Is it true that this only happens to 04 , 05 and 06 years ?
Originally Posted by VQ35DE
(Post 898549)
Is it true that this only happens to 04 , 05 and 06 years ? PDF title raised this question.
Some early ignition switches may be on a few later year cars, it also may be true that some late 06 cars may have the new switch. |
So all 2008's will / should have the new switch ?
(Post 898551)
