Gas smell coming from the outside
Hi folks!
I noticed an issue that might not be good lol! Whenever I roll down the window I get a strong gas vapor smell sometimes more sometimes less into the car. I vaguely remember stumbling over a thread talking about the possibility of gas hoses getting brtitle and drops of gas spilling into the back of the car and even under the passenger seat. I don't think that is the case as it will only smell when the window gets rolled down. It is coming from the outside perhaps the exhaust tip? I haven't been able to investigate as I just noticed it.
Any input or ideas would be appreciated. I really hope my cat converter isn't shot! What could be the cause? Was the wrong oil used in this car? I have had my oil changed with MB certified brands most of the time Mobil 1 but went with Castrol a couple of times...always from the MBA certified list but who knows ifor someone used the wrong stuff. I sure hope not of course.
thanks for your input folks!
Nick
Nick
Re: Gas smell coming from the outside
Hi folks!
Nick
Nick
I think you misread the post you refer to. Brittle hoses are sometimes found under the car, on the passenger side and close to the fuel pump and fuel filter. Fuel spillage into the car could come from the fuel filler hose or the fuel tank cap with the level sensor in lt.
Outside the car I guess the smell severity might depend on the wind direction if you had a leak around the pump/filter area.
Thanks for both of your ideas. You see, I suspected the passenger rather than the car untill I rolled down the window and it hit me 10 fold.
ii wil have to start with the hoses. Now, could it be an oil leak, too? I'd assume it would smell similar and would then obviously come from the front? It's hard to pinpoint it down so far from just driving around so far.
I have enjoyed reading both of your posts on the forum for years and so I figured I'd ask what is common on those cars in respect to gas/oil leaks as well. Will be back a bit later but thanks for all the help!
So you get the smell when driving around or stopped?
if stopped, I would take the plastic cover off under back your car, beside the passenger get rear tire, or shine a light and look on top of the bottom of the plastic cover.
if while moving, I would check the test port on the fuel rail and make sure the valve stem is good and it has its cap.
or if you think a oily smell, then see if valve cover gasket leaking some and getting oil on the header.
popeye
04-28-2008 08:27 AM
