Misfire and backfiring help
Re: Misfire and backfiring help
I am having a misfire cylinder 6 on my crossfire. I have changed the MAF Sensor, new wires, new coil packs, new fuel injectors and car is still running rough. I replaced all the cracked vacuum lines, no leaks. Anyone have any other suggestions? Would a bad lifter cause a cylinder 6 misfire. I out the timing gun light on each wire and the coil pack on cylinder 6 and 5 were a bit jump with firing order so i switched them all around.I put all new spark plugs in too. I dont think thats the problem though. Suggestions...
JHM2K
57
06-06-2014 01:36 AM
jbishop
29
06-01-2013 03:29 PM
Fjp3105
29
08-09-2012 05:27 PM
