Metallic Vibration/rattle in the front when accelerating hard.
Old Apr 8, 2019 | 03:39 PM
Dustin_Campbell's Avatar
Default Metallic Vibration/rattle in the front when accelerating hard.
There is a rattle when I hit the gas hard when accelerating, only in the front. Not the rear. Doesn't happen when back up, but I have back up hard bc that's dangerous hahaha but I think it might be the heat sheild around the engine. It's loud on the outside and inside of the car. It's very annoying and not sure where to start of finding where the metallic, vibration noise is coming from. I could use all the help I can get. This is my first car and want it to last a very long time. Car isnt new by the way. Has 137,861 miles
Old Apr 8, 2019 | 03:56 PM
zip439's Avatar
Default Re: Metallic Vibration/rattle in the front when accelerating hard.
Check the engine mounts. While in park, open the hood and have a helper rev up the engine. Can you see the engine twist from the torq?
Old Apr 8, 2019 | 04:54 PM
The engine will naturally twist a little when it's revved? What would I be looking for in order to see what's rattling...
Old Apr 8, 2019 | 09:16 PM
zip439's Avatar
If it's twisting excessively a motor mount is shot and the engine is knocking up against a heat shield. Look at the exhaust manifold if you see excessive twist. Also the honey comb in the catalytic converter could be broken internally.
Old May 15, 2019 | 10:39 AM
liljay's Avatar
Belt tensioner damper (shock). If you have a manual.
pbrowett
Apr 19, 2018 02:52 AM
ohnoesaz
Oct 8, 2008 04:56 AM
klamathpro
Jun 8, 2008 02:53 PM
andrewnhill22
Aug 23, 2007 02:12 PM
saldous
Nov 26, 2004 06:53 AM
