Spoiler issues/seats don't work/ A/C cooling issues / Damaged piece behind the seats
Hi everyone!
I figured I'd post numerous questions/issues in one thread and hopefully someone can help out a bit. Thanks in advance. 1) Spoiler is always out and the spoiler led on dashboard keeps blinking. Sometimes when the car gets started spoiler will automatically lower itself but within seconds go back up at which time the light starts blinking and the spoiler can not be redacted. 2) Both Power seats do not work anymore. None of the buttons does, whether it is back/forth, up/down or tilting it. 3) Seems like AC is not as cold as it used to be. Especially when it's hot outside I'd wish it was aa freezing cold as it used to be. also, even though rarely one side starts blowing warm/hot air for a while then all of a sudden switches to cool again. 4) I have attached a picture of the cracked head of the plastic trim behind the seat. Is that easy to replace and what's it called? If possible I'd probably purchased a used piece. Any instructions on how to assemble? Thank you for all your help. Nick https://cimg7.ibsrv.net/gimg/www.cro...dfe347220f.jpg The three issues happened over time and on separate occasions so I don't think they are related. |
Re: Spoiler issues/seats don't work/ A/C cooling issues / Damaged piece behind the se
(1) Usually a weak battery
(2) Probable the Power Seat regulator under the dash. It is plug and play. Use the search function and you will find specifics. (3) Your AC probably need charging. (4) Those bulkheads are almost impossible to find. I would use some good plastic epoxy. You could also try parts for sale on this site. Good luck, almost any information is available here with the search function at the top of the page. |
I think ZERACER meant power seat relay.
YEP, thanks.
Ordered relay today today! Seems easy enough and especially for a cheap price. That should solve the seat issues.
Any tips on the spoiler problem? Thanks for the advise guys! |
Charge the battery , mine was doing the same but I left a charger on for a night and it went away. If older than 3 years, replace.
it is for sure the battery, mine did the same thing, bought a new one and the issue was fixed.
I know it's a common problem when battery is weak but mine is brand new. This whole issue started happening once I had my wing painted by the body shop. I'd assume when they took it off they screwed up something putting it back together.
From reading some posts I heard there is some issues with switches I just don't know where to get those or what I'm really looking at. But then again I also haven't taken it apart yet. Figured I'd take the trunk latch apart to get to the wing motor and I'll first and foremost make sure that all connections are solid. I guess if all else failed, I'd get a used spoiler motor and would see if that helps but I'd rather not go that route. So any further insight on this is greatly appreciated. |
| All times are GMT -4. The time now is 10:25 AM. |
© 2026 MH Sub I, LLC dba Internet Brands
