Door lock/unlocked stopped working
Old Apr 8, 2022 | 07:56 PM
nickwe21's Avatar
Default Door lock/unlocked stopped working
Love this car but it's been one thing after another lately. When I press "unlock" on key fob the front lights will flash as er normal and I hear the beep (installed that a while ago) but the door won't unlock. I then use my key to manually unlock and that works.
NIt sure if connected to my issue with the hatch slightly leaking but I don't think it would be enough water coming in to actually get into the electronics in the trunk. I don't have water in the trunk well or the carpet in the trunk so hoping that's not my issue.
Any ideas of what could cause the hydrolics of the door unlock/lock to stop working?
Old Apr 8, 2022 | 11:59 PM
Default Re: Door lock/unlocked stopped working
Does the passenger door and/or the hatch open?
Do you hear a hiss when you press the buttons?
It could be just a broken air line.
Old Apr 9, 2022 | 02:09 PM
zip439's Avatar
Hopefully onehundred 80 is correct in the post above, However the door lock/unlock is not "hydrolics". The system works on vacuum and air pressure created by a pump in the right rear of the car, AND WATER MOST DEFINITELY WILL FIND ITS WAY TO THAT REAR AREA IF THE LEAK IS NOT REPAIRED UP AT THE HATCH. The air pump is also part of the cars anti theft system. There are numerous post on the subject. You can use the search box in the upper right corner of this site.
Old Apr 9, 2022 | 02:50 PM
It would not hurt to 'poke' a hole into the two rubber plugs under the hatch area (just rear of the two drive axles under the car, so you don't have to disassemble the hatch trim/stuff under the bottom of the hatch). IF while poking a hole into those rubber plugs water runs out, you'll have to disassemble that hatch area to inspect/fix any corrosion/wiring/modules if they are damaged by water. Good luck!
Old Apr 9, 2022 | 05:43 PM
nickwe21's Avatar
Would you he able to take a picture of what area you are speaking of? Thanks man!
Old Apr 9, 2022 | 05:54 PM
nickwe21's Avatar
So the leak is still an issue for me but the door locks was false alarm. Car was sitting for 5 days and battery was nearly dead so that is why the door lock mechanism was not functioning properly. I know these cars are finicky to a fully charged battery. Here is the problem..the battery is very new but it seems to discharge within 3 days.
i thought maybe the ground wire leading to transmission might be corroded (and it was) so I replaced it but it still seems like a he car doesn't hold a charge.
Old Apr 10, 2022 | 12:06 PM
Search forum for how to find/fix a parasitic drain, sounds like you have something not shutting down OR a leaking current issue. Make sure you disconnect the battery until you are ready to look for any parasitic drain or you'll further damage (if it is not 100% OK now) the battery. I do know once a wet cell drains down to a certain level, it never returns to a full charge. The cell plates 'sulfate' reducing its ability to provide peak current (power). Using a good quality charger that conditions/helps with minor sulfation should restore it quite well (depending on if and how much is present), but if you just have a parasitic drain (and you fix it) the battery might not be damaged at all. In my opinion, a corroded ground cable could not 'drain' a battery while standing, it'll just severely limit its ability to allow current to flow when needed. Doesn't hurt to replace it since it needed it anyway though. Good luck!
About the rubber plugs under the rear of the car, they are located just behind (rearward) of the axles on the bottom of the well area (lowest point). There is one on either side easily seen if you lay on your back and slide under a little. If you get into the lower area under the carpet & styrofoam (where the tire kit and jack is stored), you'll see them from above inside the bottom of that well space. Just puncture a hole in each of the two (one on each side). If water gets in, it'll simply drain out below the car.
Old Apr 11, 2022 | 06:44 PM
Deepsea21's Avatar
. It would not hurt to 'poke' a hole into the two rubber plugs under the hatch area (just rear of the two drive axles under the car, so you don't have to disassemble the hatch trim/stuff under the bottom of the hatch). IF while poking a hole into those rubber plugs water runs out, you'll have to disassemble that hatch area to inspect/fix any corrosion/wiring/modules if they are damaged by water. Good luck! .
First thing I did when I got my XF was poke those 2 plugs out of the R and L trunk wells from underneath. Sure enough, water came draining out. No need to worry about that anymore with those plugs popped... There may be a leak but it will drain and I won't have to deal with submerged pumps and electronics in that right trunk well.
Old Apr 11, 2022 | 06:50 PM
Deepsea21's Avatar
Yeah, if you don't have one and have no idea how to use one it's time to buy a cheap multimeter on Amazon, watch a few videos on how to use it, and then hook it up, measure the drain, and start pulling and replacing fuses 1 by 1. Been there and done that. As another posted... search your problem here and someone has probably dealt with it before.
Old Apr 18, 2022 | 04:13 PM
nickwe21's Avatar
Could you take a picture? I still don't know what I'm supposed to poke 🤣 but to he safe I'd like to do that to make sure.
Old Apr 18, 2022 | 05:15 PM
Underneath, attached to the rear bumper is a small plastic panel with I believe is four T20 Torx screws and two 10mm nuts holding it on. There is one panel on each side. It you remove that panel you will see a rubber stopper about 3/8 inch in diameter in about the middle. Grab that with a pair of pliers or vise grips and pull it out. Relace the panel and you are done.
magnuman
Mar 29, 2021 04:04 PM
JereRB
Jul 6, 2017 05:09 PM
tammylosee
Jul 22, 2016 12:08 AM
2006Crossfire
Sep 22, 2014 05:08 PM
green-ghost
15
May 7, 2011 03:02 PM
