Slow shifting auto stick
Old Jun 1, 2006 | 10:51 PM
fuzz 40's Avatar
Default Slow shifting auto stick
I have the auto stick and while I expected quick shifts with the auto stick I instead have the slowest shifting auto stick in the world. Now I know that the computer will not shift gears if it will either stall the engine or redline the engine, but i am trying to shift the engine at 4k and it won't shift for at least 4 seconds. Now is this just the way the auto stick is designed or did I just receive the slowest auto stick in the world???
Old Jun 1, 2006 | 11:06 PM
FirebaseD's Avatar
Default Re: Slow shifting auto stick
Are you at WOT or just driving along? If I'm at WOT, the transmission does not shift into the next gear (yes I'm using the auto stick) until it has reached the high end HP output RPM range... if I'm just driving along like on a Sunday morning (trying to get back home with a hang over) the transmission will shift the very second I move into the next gear... so no your shift is not slow at WOT it's the computer thinking for you... hooah
Old Jun 2, 2006 | 10:26 AM
fuzz 40's Avatar
Even just crusin along it like to take its time. Could that possible be because the car is still newish?
I figured that at WOT the car was not programmed to shift because you where at WOT and the computer is more accurate then me looking at the tact.
Old Jul 28, 2006 | 06:48 AM
6106b's Avatar
Hello I am a newbie just bought a '05 Blaze Red Crystal Clear Coat Roadster with Dark Slate/cool Vanilla two tone interior auto-stick The auto-stick trans only goes to 4 on the indicator box in the instrument panel. It is a 5 speed, does anyone know if it should go to 5? At 70 mph the rpm is around 2,500 to 2,600 its seems very low geared to me. I feel the trans may not be going into overdrive. Can anyone shed any light on this please.
Old Jul 28, 2006 | 07:17 AM
Thirteendog's Avatar
When you shift into D that is your fifth gear. Don't you feel it shift when you push it into D?
Old Jul 28, 2006 | 07:18 AM
DragonFire's Avatar
You have 1-2-3-4-D. The D is the fifth gear. Hope this helps.
Old Jul 28, 2006 | 08:55 AM
Sharonaln67's Avatar
Welcome! Your car sounds like a beaut! This is the best site you will ever find to get help with any little detail - there is a lot of knowledge out there!
Again, congrats and welcome to the family!
Old Jul 28, 2006 | 12:11 PM
6106b's Avatar
THANKS ALOT GUYS,The gear indicator on the dash only goes to 4 so I guess the trans. is not shifting into overdrive.
Sterling57
Apr 11, 2016 06:11 PM
jimf
Oct 10, 2015 10:22 AM
Dementors
Sep 30, 2015 07:46 PM
maxcichon
Sep 30, 2015 11:38 AM
jaesa
Sep 7, 2015 01:50 PM
