Eibach - Roadster
Old Mar 23, 2008 | 06:32 PM
RPM's Avatar
RPM
Moderator
Default Eibach - Roadster
So who on here has a Roadster with the Eibach kit?
Goods?
Bads?
Thanks in advance.
Old Mar 23, 2008 | 10:30 PM
Mike-in-Orange's Avatar
Default Re: Eibach - Roadster
I put them on a few weeks ago and am waiting for them to settle a bit still. While definitely lower than stock they aren't quite as low as I expected, but I'm told to give them as much as a month to fully stabilize. Since I don't drive the car all the time it may take me longer than a month for that to happen!!
Ride quality on my Limited Roadster is not much different from stock, and in all honesty after spending all weekend on track with the car I'd like it to be stiffer for that purpose. I wouldn't have a problem with it giving a bit stiffer ride in street use either, but I'm certainly not complaining.
Old Mar 24, 2008 | 04:47 AM
RPM's Avatar
RPM
Moderator
Mike -
Is this the kit that you used:
#2552.140
http://eibach.com/cgi-bin/htmlos.exe...52455200018399?
Old Mar 24, 2008 | 06:00 AM
scooter's Avatar
the only bad thing is trying to getting the wheels properly aligned. it is still a little off even with a camber kit, but all is well and no strange tire wear. no regrets, by far.
Old Mar 24, 2008 | 06:18 AM
Iamfink2's Avatar
If you don't use a camber kit will the tires wear uneven? I think Maxwell posted a camber kit that was posted on one of the mercedes sites, has anyone used this one I think you can adjust the camber alot closer to spec.
Old Mar 24, 2008 | 08:58 AM
Originally Posted by RPM
Mike -
#2552.140
Yes, that's the one. I got mine from tirerack.com
Old Mar 24, 2008 | 09:00 AM
RPM's Avatar
RPM
Moderator
andrew and some of the others have reported no uneven tire wear on theirs.
Old Mar 24, 2008 | 09:53 AM
SRT6 Dan's Avatar
Banned
I lowered my '04 coupe a "twin" to Andrews and every set of tires wore uneven to the inside edge ! I drove almost 70,000 miles ! I did notice the Contis wore better than the P2s. They all seemed to need changing around 20,000 miles.
Old Mar 24, 2008 | 10:21 AM
scooter's Avatar
the camber kit is not worth it imo; the adjustments it provides is way too minor.
Old Mar 25, 2008 | 04:44 AM
RPM's Avatar
RPM
Moderator
Anyone else? Thanks.
Goods?
Bads?
Thanks in advance.
realglobe182
Aug 25, 2015 04:34 AM
itsky
Aug 4, 2015 10:35 PM
mattnelson71
Jul 30, 2015 10:49 PM
Jerrysrt6
Jul 24, 2015 09:15 PM
turboomni08
Jul 7, 2015 11:48 AM
