CrossfireForum - The Chrysler Crossfire and SRT6 Resource (https://www.crossfireforum.org/forum/)
-   Crossfire Roadster (https://www.crossfireforum.org/forum/crossfire-roadster/)
-   -   New Tires/ TPS light won't go off (https://www.crossfireforum.org/forum/crossfire-roadster/34502-new-tires-tps-light-wont-go-off.html)
golfergal May 16, 2009 09:50 PM
I had to replace all 4 tires (pot hole thread) and two rims. Now, my TPS light won't go off. I stopped by the tire place and they checked that the sensors were working...they were and the tire pressure...but the light is still on even after "resting" for a bit. Any suggestions on what to check?
Thanks!!!!
maxcichon May 16, 2009 09:59 PM
Re: New Tires/ TPS light won't go off
Sorry to say that the dealer must "teach" the individual sensors if their positions have changed.
James1549 May 16, 2009 10:09 PM
The position shouldn't matter. When I had the original Contis, I rotated them side to side with no problem.
Is the tire pressure adjusted to the specs listed on the door or jam? The tire will give you max air pressure, not pressure recommended by the car manufacturer, which your TPMS are calibrated at.
I don't know what else could be wrong except a damaged/defective sensor.
Dealer time, then take the receipt back to the tire shop if they find a damaged sensor.
James
Caught in a Xfire May 16, 2009 10:16 PM
James
i think he's right[bad or damaged sensor]. :(
golfergal May 17, 2009 12:24 AM
There appears to be a valve that looks suspicious on one of the tires. I might think the pot hole that damaged my rims and tires may have contributed, as well. However the valve is on the opposite side. Heck, with all the dealerships going down the tubes, I hope my local place is still working on our cars. Word of warning...Don't hit POTHOLES!
James1549 May 17, 2009 12:29 AM
Please explain...
golfergal May 17, 2009 12:43 AM
I had the tire place set the pressure to 34 PSI. He did use some gadget to check the sensors and they came up on this computer screen that they were working...according to the gadget...
James1549 May 17, 2009 12:52 AM
You missed my request...
golfergal May 17, 2009 01:53 AM
According to my husband..it's not perfectly circular. It's oblong in shape..crimped, IOW.
Caught in a Xfire May 17, 2009 09:02 AM
can you post some pics of it?
© 2026 MH Sub I, LLC dba Internet Brands
