Low Beam Headlight Adjustment
Old Aug 17, 2011 | 12:51 AM
OldSalt's Avatar
Default Low Beam Headlight Adjustment
Got all the info to adjust the RT head light. I tried to re position the low beam bulb but it did not help. It seems to be positioned properly.
If I adjust the the RT light won't that also affect the high beam?
My only other idea is to unhook the lock bale on the bulb and hook the connector and move the light in the socket and see if that will help me find the correct position.
The RT low beam hits only a few feet from the car but the RT high beam is fine. Left low/high beams are fine.
Thanks
OldSalt
Old Aug 17, 2011 | 06:36 AM
maxcichon's Avatar
Default Re: Low Beam Head Light Adjustment
Thanks
OldSalt
It really sounds like the bulb is mis-seated. I had the same problem until I adjusted the seating by hand with the clip loose and the headlights ON. It doesn't get hot, so go for it. When it hits the sweet spot-you'll know it!
Old Aug 17, 2011 | 09:36 AM
Paul Bosslet's Avatar
The headlights are very finnicky. The bulbs must be aligned and seated properly.
Old Mar 18, 2018 | 12:23 PM
Mommasride's Avatar
Ok I noticed this yesterday playing with mine. The adjustment screw is cheap plastic. I wanted them as high as possible. Screwing out will move them up but I turned it too far and the plastic screw popped out. The end of the screw has a ball shape to it that fits into the housing that must have socket hole. To reseat it I had to screw it all the way in till it pops back in. Then screw it out but not too far or the ball will pop out again. Hope this helps.
onehundred80
Apr 16, 2025 04:43 PM
romanylife
Sep 8, 2019 06:21 PM
BobaFettm
Mar 19, 2018 11:35 AM
Salty Dawgs
Dec 25, 2016 12:51 PM
DHS
Oct 23, 2016 04:50 PM
