strange noise
On the weekend, it was a little frosty. Started my crossfire -no problem. However, I heard a strange sound. Investigated and it seems to be coming from the belt at the front of the motor. Sounds like something is stuck on the belt but I could not see it.
Is that the serpentine blet? Is it okay to drive it a mile or so to my mechanic?
I left it at home and drove my winter beater to work today.
I have an 05 roadster with 80,000 kims (49,000 miles)
thanks
thanks
If it's the squealing type of noise either the belt is a little bit glazed or there was some moisture on it. Not a big deal. You can try buying some spray on belt dressing to see if that cures the problem. Otherwise you can replace the belt or live with the noise.
not so much as a squealing noise but more like a cluncking noise - and it is not consistent - just every ferw seconds which is indicative of a belt rotation.
thanks guys.
thanks guys.
I had that "clunking" noise when I hit about that mileage. Was the water pump and they told me I got it to the dealer more or less just in time. Was replaced under the extended warranty. I too thought it was the idler pulley but if it's the pump you can actually see the pulley move up and back because the bearing are shot.
It will also allow you to check the individual components that the belt operates.
1. you will need a 17mm socket and wrench or pull handle.
see https://www.crossfireforum.org/forum...placement.html
While you have the belt off, first inspect it for cracks or separation, replace it if needed.
Inspect the water pump pulley ( it's the black metal one with 4 bolts sticking out ) if it has appreciable play up/down - side-to-side then you will need a new water pump.
Also rotate all the movable pulleys / idlers by hand checking for noises, replace as needed.
ty_ty37
Jun 27, 2024 10:42 AM
2005 Ragtop
Oct 3, 2015 03:01 PM
steps
Sep 19, 2015 10:43 PM
