Front end covers
Old Feb 10, 2012 | 08:47 PM
dickyb's Avatar
Default Front end covers
I'm having trouble finding a front end cover [bra]. Any suggestions?
Old Feb 11, 2012 | 02:05 PM
Hindin's Avatar
Default Re: Front end covers
If you want OEM (which I strongly recommend) you can order one from your local Chrysler Dealership.
Old Feb 11, 2012 | 03:21 PM
Kodebuster's Avatar
You should do a search on 'bra' as you'll find a decent discussion on the item.
Downside is that over time you are subject to wear and possible scuffing of Clearcoat and your paint job. Also, it's a hassle to keep the area clean under the bra (dirt & debris).
If you think the Black Bra look is kool, then go for it.
If your goal is more along the lines of protecting the frontend, bumper, and headlights, my prefered solution is a 'Clear Bra", and specifically the 3M Brand ( 3M Scotchgard clear bra).
I put the Clear on my car and love it, it rocks (pardon the pun)...
Old Feb 11, 2012 | 03:31 PM
Kodebuster's Avatar
Also, check out this link if you want additional info on the 3M Clear Bra (there are also some kool pix of exotics getting a full body wrap):
Paint Protection | Detailing Dynamics
Old Feb 11, 2012 | 10:17 PM
gryfan's Avatar
you will find that the colour of your hood will be 2 different shades from the scuffing..........think of what a woman looks like when she takes her bathing suit off after sunning. the area covered by the bra is not the same colour as the rest.
i think that makes a great visual. no more explanation needed.
gryfan
Old Feb 13, 2012 | 12:21 PM
papas34's Avatar
Tan lines.........woman...sexy.........automobiles.... ...not so much
Old Feb 13, 2012 | 05:33 PM
Goldwing's Avatar
I've had a bra on the roadster since it was new and there is no discoloration. Caveat - it is garaged when not in use and usually under a car cover. Also, I put several extra coats of wax under the bra and remove it regularly to clean under it, plus I take it off when storing the car for the winter. Furthermore, I rarely run the Crossie in the rain so very little crap gets under the bra. Now I have discovered a couple very light wear marks down low on the grill, but they are less noticeable than rock dings of which there are none. And, if I don't like the look of the bra or want to show the car, it comes off in less than two minutes. Going back on takes a little longer, but not much.
PimpDaddy
Mar 31, 2020 07:22 PM
stlas69
Sep 3, 2015 10:28 AM
hhr hellshotrod
Aug 17, 2015 11:27 PM
Bayukbros
Jul 29, 2015 10:16 AM
waldig
Jul 20, 2015 08:10 AM
